Chapter 1/ LS1Tech Project/ Supercharged Formula
Old Mar 3, 2003 | 11:34 PM
  #41
JimmyKash's Avatar
Default Re: Chapter 1/ LS1Tech Project/ Supercharged Formula
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Pro Stock John:
<strong> Bob said the softeners are allowed but really don't help.
Chapter 2 will be about the supercharger and the intercooler. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">interesting....i've had a few friends that have used softener with great results but at the price of the wasted belts. I remember Larry @ ASSC was telling me about using some on his daily driven D-1 formula and it made his boost go from 11psi to 15psi and he detonated the motor. Luckily it didn't crack a ringland.
I've personally also used some on my friend's mustang and it helped his belt problems at the track.
*shrug*
Old Mar 4, 2003 | 12:56 AM
  #42
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
3/3/03:
Rods are here, pistons should be here any day now.
Dropped off my new LS6 crate motor at Speed Inc. so they can get it honed .005 for me.
I will be dropping off a low mile stock crank there in the next week or so and then I will have them balance the new rotating assembly.
FMS is pulling together my order for a big HP blower cam, springs, retainers, ARP main studs and double timing chain, along with other odds and ends.
The 6.0 FI heads will be on their way this week and the 6.0 GM head gaskets are already here.
I plan to buy one of those SDPC engine stands and then the motor should be done by the end of the month or even sooner.
I still need an oil pump and headers to complete the longblock.
Sorry I have not posted all the prices and part numbers, I will once I have complete and accurate lists from the companies from whom I am buying the parts.
<small>[ March 03, 2003, 12:58 PM: Message edited by: Pro Stock John ]</small>
Old Mar 4, 2003 | 09:25 AM
  #43
Mike 01WS6's Avatar
I think i speak for everyone when i say....Post videos and dyno sheets as soon as it's done! <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" />
Old Mar 4, 2003 | 09:47 AM
  #44
LQ4somona's Avatar
This engine should make very good power. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> But reliability may be a question. What level of boost is the limit for the stock sleeves? Or has anyone hit that level of boost yet? This will be an interesting peice, good luck. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Mar 4, 2003 | 10:43 AM
  #45
LS1Tech Co-Founder
Well the record for SC'd power using aluminum block with a stock sleeves is ______, I have no idea. I'm sure there are some examples in the 6__ range.
Jimmy, I have no experience with the softener but Bob does not use it and he is one of my advisors on the project, but I'm sure it works for folks. Larry's 3rd gen is fast but it's dual power adder and I am reluctant to use those R-trim/ spray setups as a reference.
I am gonna have it pulleyed for 20 lbs of boost but it will be a while before it would see that.
I am looking now at how high we can spin the hydraulic setup. I plan to run very little preload, like .010, but I wonder what will happen if we try to shift the car at 7200... Just random thoughts right now, I plan to have the longblock assembled by the end of the month, and I will have exhaust and the trans in to if I can find a T400 in time. I might dyno the car NA too.
Old Mar 4, 2003 | 10:56 AM
  #46
CHRISPY's Avatar
I think you should go solid with STRONG springs if you are planning big revs <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Good luck,
Chris
Old Mar 4, 2003 | 09:53 PM
  #47
onfire's Avatar
Coal Mining Director
<img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" /> Stock crank <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Old Mar 5, 2003 | 05:44 PM
  #48
LS1Tech Co-Founder
I'm going to post prices now, but I will be editing this post many times until I have all the prices and part numbers... Keep in mind that the prices can vary a bit.
Chapter 1/Longblock and total cost:
FMS/PSJ blower Cam: FM-9900 $429.99
Rollmaster Double timing chain: 105-1160 $84.95
Crane double valvesprings: $110.80
Federal Mogul rod bearings: $82.95
OEM Ported oil pump: $125.00
LS6 crate block: $570 (private party)
6.0 stage II FI heads: $1900 (Chris Gelineau)
GM 6.0 head gaskets: $50 (private party)
ARP main studs: $__
Custom H-11 Head studs: $__
LS6 intake: (already had this)
OEM Water pump: (already have this)
Labor, cylinder hone .005: $__
Labor, balance rotating assembly: $__
Labor, assemble shortblock: $__
Miscellaneous gaskets: (water pump, intake)
Lifters: $__ (new stock ones)
What am I forgetting?
Old Mar 5, 2003 | 06:50 PM
  #49
onfire's Avatar
Just curious...why GM vs Cometic head gaskets...all LPE turbo cars use cometics...
Old Mar 5, 2003 | 06:59 PM
  #50
SStrokerAce's Avatar
How about a ported TB?
Old Mar 5, 2003 | 07:06 PM
  #51
Mike Hoffpauir's Avatar
<strong>
RWHP, well... I'm gonna use a T400 transmission and it won't have lockup, so let's say the equivalent of 800 crank HP. I'm going to run the T400 for now and then swap in a 4L80E over next winter. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">PSJ, with your experience with the flp 4l60e do you think your new setup is just going to be too much for it?
Also, what brand and spec convertor are you thinking about.
In general, I was reading all this build up and wondering about the chassis. I guess I'm jumping the gun on another thread <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" />
Old Mar 5, 2003 | 09:25 PM
  #52
Holes02's Avatar
Good luck with the buildup John.
I take it Mr. Bob Kurgan (Mr. Renegade) is the gentleman you're referring to as far as advising you about your setup?
I thought they were able to use a t-brake in Renegade competition?
I'm also curious as to why GM gaskets instead of Cometic?
Old Mar 6, 2003 | 11:45 AM
  #53
LS1Tech Co-Founder
Yeah I need to add a TB to the list. How much are your Bauer TB's, that is what I am using. I want one powdercoated in red.
Harlan is using the GM gaskets and based on his numbers he is making 700rwhp on a Eddy current dyno so he's more like 740rwhp on a Dynojet.
Renegade folks do use a T-brake I was in error when I posted that. But I will not use one since I am not looking to keep a T400 in the car long term.
My FLP tranny worked great and I was tempted to try to use it but if I smoked it I would have smoked a $2000 transmission just to satisfy my curiousity. Better to sell it for $1500 and get a $750 T400 (no brake). I am going to use a TCS 245mm converter, I hope to get one to stall around 5200-5500 or so, and I plan to shift the car around 7000-7200 rpms. I should make 20 lbs of boost doing that. I am gearing down in back from a 4.11 to a 3.50 gear as well.
<small>[ March 06, 2003, 11:47 AM: Message edited by: Pro Stock John ]</small>
Old Mar 6, 2003 | 03:58 PM
  #54
LS1Tech Co-Founder
ARP main studs: $130
Custom H-11 Head studs: $350
Labor, balance rotating assembly: $300 (est)
Labor, assemble shortblock: $300 (est)
Labor, machine heads for double springs: $50?
Miscellaneous gaskets: $80
Lifters: $0 (free from low mile junk motor)
OEM ported TB: $150? (Bauer Racing)
Old Mar 6, 2003 | 04:50 PM
  #55
BradWS6's Avatar
I don't see injectors? or is that in the list with the fuel system down the road?
Also why are you going to use used lifters?
Old Mar 6, 2003 | 05:16 PM
  #56
LS1Tech Co-Founder
83 lb Delphi injectors (low impedance)
Barely used lifters, <1000 miles
I'm not necessarily believing that the aftermarket lifters are much better than stock. And I used to have a set of Comp R lifters.
Old Mar 6, 2003 | 05:37 PM
  #57
RyanJ's Avatar
SSU Moderator
Wouldnt you want to use some good aftermarket lifters for an FI/high rpm motor? Something like Comp R's or the Schoelfields (sp?).
Also, don't you have to clearance rockers to use the cranes?? Why not just use Isky's, REV's, or Comp's doubles. They have been proven.
Old Mar 6, 2003 | 09:15 PM
  #58
OEM ported TB: $180? (Bauer Racing) </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Hey you should at least get some stock lifters shimmed up to run any sort of cam with some lift.
I could probably handle that too.
Bret
<small>[ March 06, 2003, 09:21 PM: Message edited by: SStrokerAce ]</small>
Old Mar 7, 2003 | 10:38 AM
  #59
LS1Tech Co-Founder
I have run stock rockers up to 7400 with no ill effects.
I think most of the aftermarket lifters are just modified stockers. I have never seen a stock lifter fail in the last four years.
I'm not running more than 600 lift and I am only going to run about .010 lifter preload.
Old Mar 7, 2003 | 11:32 AM
  #60
Terry Burger's Avatar
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Hah I've been down that road. Good luck. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
