Should I get new rockers?
Aftermarket stainless steel valves have a 2.02" intake and 1.6" exhaust diameter.
I was thinking about the xr281hr grind from comp cams as this should put me around a .571" lift, with stock rockers.
My thought was get a 1.7 ratio rocker set to put me near .600" lift, thus getting the best airflow with my new heads.
Heard some old war stories back in the early 2000's with problems with some of the aftermarket rockers for the ls1 out there. What have you used and how has it treated you?
Not looking for someone to post on what they just bought, no offense but looking for real data. Thanks!
I don't use them anymore. Now stock rockers are used. Have used 1.7 rollers w/ XER lobed cams & 1.8 rollers on stock lobed/low lift cams. IMO, roller rockers are not worth the expense.
One thing to watch for with stock rockers & higher lift aggressively ramped cams are the bearing retainers popping off & dumping needle bearings into the head/engine. There is a kit sold that is a cage for the needle bearings that eliminates this problem. To me, the kit is also over priced. So, I just tack weld the retainer to the rocker. This keeps 'em from popping off (see pic).
