Gen 3 with VVT?
Old Sep 13, 2010 | 05:51 PM
3.8redbird's Avatar
Default Gen 3 with VVT?
Can I get a LQ9/4 shortblock and add a VVT cam, phaser, and oil pump along with an L92 computer to enable VVT?
I already have everything but a shortblock to run VVT. This will not be a raced car. I want to make a reliable daily driver is all.
Old Sep 13, 2010 | 08:05 PM
SHovV's Avatar
http://www.hotrod.com/techarticles/e...arts_list.html
Old Sep 13, 2010 | 09:27 PM
3.8redbird's Avatar
I swear your stalkin my threads man lol
good deal. All I need is the reluctor wheel then. thanks
Old Sep 13, 2010 | 10:31 PM
SHovV's Avatar
Old Sep 15, 2010 | 08:46 AM
Schwanke Engines's Avatar
LS1TECH Sponsor
You could just use a gen 4 block with no problems, just need to run the 58x reluctor which we could do.
http://www.schwankeshortblocks.com/s...?i=1491&c=1216
Old Oct 17, 2010 | 03:17 PM
turbinesurgeon's Avatar
Do you really need the L92 oil pump to run VVT? Also wondering how deep the valve reliefs would have to be for a performance VVT cam.
I'm thinking of converting an LS1 to VVT. I've read the Hot Rod artical on it, wondering if their are any other details I need to consider to make it happen.
Old Oct 17, 2010 | 09:44 PM
3.8redbird's Avatar
you need a higher volume oil pump. There needs to be more oil pressure for the phaser.
I would talk to comp cams or MAST about a performance version
Old Oct 18, 2010 | 03:57 PM
Ok, makes sense for the oil pump. I got the Mast info on the performance version, will probably go that way along with their M-90 controller.
What about the valve reliefs? I can find pistons with -4cc reliefs pretty easy. Would that be good enough to run VVT?
Old Oct 18, 2010 | 04:05 PM
3.8redbird's Avatar
I honestly wouldnt know. It depends on what phaser you use as well
By Brett Foote | 2026-06-04 05:00:17
