Coolant crossover tube at back of engine...needed?
The question is, is this safe? Could that have caused the heat that may have destroyed my motor? (seems like it let go around #7) or is it normal to just block off the back ones?
I am installing an LQ4 as a replacement for my boomed motor and am considering making a crossover for the rear as well. What are yall running?
Good luck
I then attached some 1/4" Rubber Fuel Line to the Rear and plumbed it and the Front Crossover to a "T" Fitting and then to the Radiator.
It really wasn't that tough and it insures each cylinder is being properly cooled.
But, again, its probably overkill since GM installed the Rear Block-offs from the factory on 2001 and up LSx equipped vehicles.
Mine's already taken care of with block off plates, but I'm just curious
rovided the coolant system is properly evacuated***. The coolant that surrounds cylinder 7 & 8 has ONLY been through the block, by the time is makes it back up towards the front of the engine, it has passed a mixture of the block and multiple combustion chambers, and the combustion chambers are where the majority of heat comes from. The front of the engine has better ***EDIT: external*** air cooling though. From the gauges, it shows to run about 3-5*F cooler on cylinder 7 versus cylinder 1. Last edited by 1SLwLS1; Sep 24, 2010 at 09:24 AM.
Kurt
The tube that connects the front to the back and goes over the valley cover was elminated for Fbodies in 2001 and in stock form its not an issue.
You can grind on the intake, it wont hurt it. People do it to clear that tube. OR cut off and JB weld the ends. OR just get a 01+ set of lines, and then again just cap them off all together. It's a personal choice and do what you feel is right.
