Best way to pull off heads without coolant everywhere
I found this drains more coolant out than a shop vac (which I have used in the past). The engine block, water pump and radiator and all dumped this way.
Also in general, people will always drain the radiator first, and then remove the lower radiator hose off the pump and you tend to get the majority. In most cases this will be all that you need to do.
