Forged questions
Old Sep 16, 2010 | 09:08 AM
ND400's Avatar
Default Forged questions
Ok basically I'm looking at doing something unheard of here in Australia. A forged 347ci turbo.
Mahle pistons, standard compression
Manley h-beam steel rods
GM head gaskets.
ARP studs throughout
Standard 241s
LS6 block
LS1 or 6 cam
Garrett GT45 series turbo
Fuel system
I would like to see what kind of life expectancy I can expect from this setup, mileage and boost on STD compression possibly 12-13 psi.
Any input appreciated
Old Sep 16, 2010 | 01:52 PM
HOHN's Avatar
Life expectancy is all about how much power you use and how you prepare the engine for it.
Mileage will vary with how you use the power. If you seriously care about fuel economy, go with the largest turbine housing (1.44A/R) for the GT45, as that will cut backpressure and make it easier to stay out of the boost.
A good part of how this setup will run is the charge air cooling. If you can keep that charge nice and cool at 12psi, it will act a lot like a stocker--- with a couple more horses Assuming you are on a good part of the map, discharge temps will be about 215°F (assuming 90F intake temp and 70% efficiency).
You'll need to go up in injector size a good bit to use a GT45 to where it's capable.
Old Sep 16, 2010 | 07:08 PM
slowassta's Avatar
if you are sure you are boosting it, get dished pistons to lower the compression ratio
Old Sep 17, 2010 | 10:27 AM
ND400's Avatar
See here is where I wanted to be different. Have an LS1 that goes like a Bolton ls1 of boost. Then when the hairdryer goes off crank it to 11.
I was referring to mileage as life expectancy. I have the perfect tuner on the job so that's not going to bring up any issues. GM MLS head gaskets, GM cam bearings, GM main bearings. Morel link bars or howards lifters. And a standard cam with PAC 1521 that won't rev past 6600rpm or 6800max
