Any one ran this cam before?
Just curious if any one has any history with it.
Comp cam 54-428-11 Grind #XR281HR
Hydraulic Roller Lifter
High RPM street strip
RPM Range 2200-7200
Timing .006
Lobe center angle 112
Intake centerline 110
Valve lash is hydraulic on both
Duration intake 281 ex 283
Duration .050" intake 228 ex 230
valve lift intake 0.571 ex 0.573
lobe lift intake .0336 ex 0.337
How did you tune yours once installed? It says it requires tuning. I am looking at the options.
How did you go about tuning you car after the upgrades?
I am with everyone else, no need spinning that cam to 7000+ rpms. That is not a bad thing though. What rods are you running? If stock, what rod bolts? You really do not want to spin the stock rod bolts past 67-6800 rpms IMO. You will be able to tell more about it when you get it on the dyno. I would guess that cam will probably start falling off around 62-6500 rpm.
As far as your tunning question? What computer setup do you intend to run? Most swaps I see, people use 99' - 02' fbody computers and they tune them with hptuners. If you do not have a computer yet and plan on buying a f-bod computer. Stay away from the 98's. They are a little tougher to get tuned.
Sounds like a nice build you started, should fly!
The only thing I did was buy the cam setup from comp cams and they recommended all the parts that go with the valve train. It is my first true engine build and I figured why no do it right even though it cost a little more. I dont have anyone to help me or walk me through ideas here.
I bought a stand alone harness from Speartech and a ecu from them. He went through and modded the ecu already by bumping the rev limit up to 6500 and taking out emissions, since my car does not need to run them, I'm an Ozone killer I know. Can I tell by the serial number what year it originally came from?
I dont need a full 7000rpm. I am looking at a road racer view point, if I am on the track and need that little bit of stretch to be able to hit the next corner without shifting then it would be nice. Also it helps with the top speed if I ever need to pull my 5th gear setup to 180+. The engine rpm calculator shows 7k rpm is about 210 mph, LOL.
Thanks for all the inputs
