Adjustable rockers
Old Jan 27, 2004 | 06:46 PM
CHRISPY's Avatar
Default Adjustable rockers
Anyone have any information on adjustable LS1 rockers? I would like to use the rockers to adjust my preload with the comp R's and not screw around with shimming them.
I have heard of a couple in development but are there any out on the market now? Any pricing info? (hopefully not 800 bucks US or something outrageous like that)
Chris
Old Jan 27, 2004 | 07:48 PM
Country Boy's Avatar
Senior Member
If your motor can handle it, Try the Comp Pro Mags http://www.compcams.com/Technical/Pr.../ProMagnum.asp Adjustable, rebuildable, lifetime warrenty and cheaper than any others.
The ONLY bad thing Ive seen is that the only ratios are 1.75 and 1.85. Thunder sells them for a good price.
Old Jan 27, 2004 | 10:23 PM
LOnSLO's Avatar
I'll second the Pro Magnums. I have put them on a couple of LS1 motors, and they are super nice. I also like the T&Ds. They are on my motor.
Old Jan 28, 2004 | 01:37 AM
TApimp's Avatar
i have some rockers for sale pm me if ur interested
Old Jan 29, 2004 | 05:37 AM
Spinmonster's Avatar
I was debating solid roller myself and didnt want to go with 1.75-1.85's or go with aftermarket valve covers or spacers. It turns out that Vinci makes an adjustable 1.7 that fits under the stock covers. They are similar to the crane 1.8's but in the stock ratio. They come with hardened pushrods and guide plates. $650 on the VHP website. It is a bargain when you consider the savings for coil relocation, covers, spacers, and the cost of shaft mounted adjustables. Good luck with the hunt.
Old Jan 29, 2004 | 10:43 AM
BB's Avatar
BB
I found them to be $699 on the web site. At least these are stock ratio.
Old Jan 29, 2004 | 11:22 AM
Blktie8's Avatar
What rockers are adjustable and are stock 1.7 to 1 ratio
Comp pro magnum rockers 1.75 and will increase lift and then coil bind is an issue ?
Only ones I know of now are shaft system and then there is the valve cover issues .
Harland sharp will be coming out in Feb with an adjustable that is affordable but still will need to increase valve cover height
Old Jan 29, 2004 | 11:41 AM
Phil99vette's Avatar
7 Second Club
Are comp Pro-Mags adjustable? They dont look like it....
Phillip
Old Jan 29, 2004 | 01:44 PM
Nasty N8's Avatar
The Comp`s are adjustable like the old scool chevy rockers are they float and are not tightened down. They require pushrod guild plates to keep them in line so they don`t walk of the valve. I should have a set of the Harlands to test in a couple of weeks. We will see what kind of clearance is needed. The problem making rockers with adjusters to fit under the valve cover is making them short enough to clear there is no clearance between the rocker tip to the valve cover. Thats where the adjuster needs to go. The Harland Sharps will be cheap and we have a sheetmetal aluminum valve cover to go along with them. I will do a special with both as soon as they are tested and made.
Nate
Old Jan 29, 2004 | 04:34 PM
07BlueDevilZ06's Avatar
i have the crane 1.8 on my car
Old Jan 29, 2004 | 08:34 PM
The Vinci ones are exactly the same as the cranes. I had the cranes and they as well as the Vinci's will fit under the stock covers with full adjustability. the center mounting nut tightens down to zero lash then you set the preload by 1/4 turns.
Phil, are you going to the shootout?
Old Jan 29, 2004 | 08:43 PM
Blktie8's Avatar
Nate
It looks like you and I will be talking again Nate ole bud.
got to have both comp R's and adjustables
John
Old Jan 29, 2004 | 08:50 PM
http://vincihighperformance.com/LS1V...RTSPARENT.HTML
Still says $659
Old Jan 29, 2004 | 08:58 PM
white2001s10's Avatar
Has anyone machined heads to take oldschool studs & rockers?
Old Jan 29, 2004 | 10:19 PM
pekkaz's Avatar
Cranes are available in 1.7 ratio, PN 144750-16. Same price as 1.8s though and '98 covers most likely need machining.
Old Jan 29, 2004 | 11:07 PM
Nasty N8's Avatar
So you don`t want the 850 lifters a John?
Nate
Old Jan 30, 2004 | 01:37 AM
frankensteinta's Avatar
The Comp Pro Magnums are adjustable as well, just like the SBC Pro Mags.
Old Feb 18, 2004 | 12:32 PM
BB's Avatar
BB
Anyone install the Comp Pro Magnums tell me about valve cover clearance? I am reading they clear the valve covers and I am hearing they don't?
Old Feb 18, 2004 | 08:27 PM
Senior Member
I had to sell mine before I got them installed I now have ones that definately dont clear
Old Feb 18, 2004 | 09:42 PM
BB's Avatar
BB
What did you settle on? Are they adjustable? Did you do the valve cover spacer? That seems to be the cheapest route - spacer and longer truck plug wires. More Performance has a sweet billet valve cover that is 1 inch taller and will take the coil packs. Still need longer plug wires and it is about $550!
