LS1 swap is running hot (over 210*F) any ideas?
Thanks everybody! It sounds like I am okay. Any thoughts on the 160*F thermostat? I have several modification to this engine. below are the mods, let me know if I should stick with the stock LS1 thermostat or go with the 160. Thanks again, Mark
85' Corvette LS1 Swap
2001 Z28 LS1/4L60E Donor with 60K miles. Factory computer, MAF, LS6 intake. No VATS, No Emissions.
Rev limiter 7,300 Speed limiter 205mph
FAST 36 lbs/hr injectors
Ported 243 Heads with light weight valves
Comp Cams 26918 Valve Springs
Comp Cams 232/234, .595"/.598",114 LSA
7.40 rods, LS7 lifter kit
In Motion Ported and Shimmed LS6 oil pump
Under drive crank pulley
Gear ratio 3.07, tire diameter 25.7"
Stock LS1 thermostat, 2-electric fans both come on at 200*
NGK TR6 4177 plugs with .045 gap
Super unleaded 93
Estimated compression ratio 10.25:1
4L60E, TCI 242931 Street Fighter 3K-3.5K lockup stall
PaceSetter 70-1341 Shorty headers, no cats, X pipe, magnaflow mufflers
Goodyear Gatorback belt 4060798 6PK2025
I had my computer reprogrammed for start up. they tuned out all the vats and emissions. They laid in a table from a similar build. Please let me know if i should make any other changes to the computer. i plan on taking it for a dyno tune in the net few weeks (got to save a few coins).
If you know of a good dyno tuner in North Texas let me know.
Thanks, Mark
Super unleaded 93
Thanks, Mark
160 thermostat is a waste of money...
doesnt matter what thermostat you put in...
you still want your ls1 engine in the 205~210 degrees Fahrenheit range when its up to full operating temps...that is where they make the best power and torque
all the 160 thermostat does is slow down the time it takes to get to full operating temperatures once it is opened...
because once it opens up.. its open....doesnt do anything after that.
So, I have spent most of the morning searching these forums looking for a good tuner in Dallas, with no luck. The only post I am finding are like a year or two old. I'm thinking if they are that old the good tuners may have left and went to work for other companies, or started their own business.
Can anyone recommend a good tuner in the Dallas area, that will take the time to drive the car and dial it in? I know that everyone will through it on the dyno and do a WOT tune....and I want that, but I also want a tune that will let me drive the car around town.
Also, how much money am I looking at?
a radiator is a radiator, as long as it is in proper working order and large enough, it will cool the engine. there is no ls1 specific radiator to be had.
OP: everything is fine. the engine is operating as it should with factory perimeters. only thing i'd do is try to achieve a full hot operating temp of ~210 as opposed to 230, which can simply be adjusted by the fans. you might be able to squeeze a few more degrees of timing into it, as well. good luck, my next project will be puttin an lsx into a c4. love that combo.
#32
Start cold motor with the Cap off. Keep feeling both radiator hoses till they both are hot
and feel about the same. Add water to radiator until you can see it circulating, top off, put cap back on. I use this procedure and never have any heating problems.
#34
OP: I have an 87 T/A with a stock 2000 camaro ls1/t56.Im using my stock radiator and stock dual electric fans.These motors like to run hot from factory due to emissions mostly.My ls1 temps idling fully warm sits around 200*.I have a 180* stat in it.While driving I get upto 220*
I removed all my a/c components but just as a safety backup of ever over heating.I reused my a/c turn on wire and a relay to trigger my primary fan manually inside the car which while driving on the highway keeps my temps right around 200-210* and never gets hotter than that.I suggest you do this aswell if you are that concerned about it,no need to run a manual switch when you got one at the hvac controls doing nothing.Good luck
#35
I think alot of guys are actually getting around 230 when their guage is telling them 210 , my car is a 98 which is supposed to have a more accurate temp guage.
