valve spring life?
Old Oct 2, 2010 | 04:33 AM
jt76's Avatar
Default valve spring life?
My valve springs (i believe they are patriot springs) were installed along with my cam 24k miles ago. Over this season, the car seemed to really be down a bit on power, my guess is i need some new valve springs? I am running a thunder racing 231/237 cam with .595/.605 lift, what would be a good set to pick up? thanks.
Old Oct 2, 2010 | 06:38 AM
soundengineer's Avatar
Since you are running a thunder racing cam...
Manley Dual Springs...from Thunder Racing
Old Oct 2, 2010 | 12:30 PM
jt76's Avatar
bumpski
Old Oct 2, 2010 | 12:41 PM
GTOworshiper9's Avatar
What lobes?
Old Oct 2, 2010 | 02:08 PM
jt76's Avatar
TR uses comp cams correct? i believe i remember reading that they are pretty agressive lobes, a step below XER
Old Oct 2, 2010 | 03:19 PM
studderin's Avatar
have them tested.
Old Oct 3, 2010 | 08:21 AM
oange ss's Avatar
they use their own lobe design
Old Oct 3, 2010 | 12:41 PM
That's not true. I have one of their stroker cams and it's on XER lobes.
OP: If you think it has the XER lobes then it's relatively mild. If you really wanted to know you could grab a couple springs and go to a shop and have them tested
Old Oct 3, 2010 | 12:48 PM
oange ss's Avatar
then they changed it, because the use to use similar lobes to Futural.
Old Oct 3, 2010 | 09:06 PM
rem308winvtr's Avatar
20k miles the springs start to go dead it is a maintaince thing with a cam that needs to be kept up on
Old Oct 3, 2010 | 09:32 PM
I tell people to test at 9k~10K miles... or after 3 "3000 mile" oil changes
after the initial 10k check.. .I check them again every 5k after that
