Timing cover gasket or RTV?
Old Oct 10, 2010 | 01:34 AM
some_punk's Avatar
Default Timing cover gasket or RTV?
I am in the process of a doing a heads and cam swap. I was wondering can I use high temp RTV on the timing cover instead of the timing cover gasket? And Everyone on here seems to say just put a dab of RTV, but on Ls1howto.com says to put a bead along the bottom of the timing cover. Which way is better?
Old Oct 10, 2010 | 01:38 AM
Arc00TA's Avatar
Use the gasket. If you have ripped out any of the rings around the bolts you will need a new one, as it will definitely leak. If you take that gasket spacing out of there your front crank seal may not work properly.
You only NEED to put a line of RTV on the corners, right where the block and pan intersect.
Old Oct 10, 2010 | 03:08 AM
BennyB's Avatar
yep just a coulple dabs at the bottom corners of the front cover
Old Oct 10, 2010 | 07:55 AM
vettenuts's Avatar
The key thing is to center the cover on the crank, and measuring with a 6" metal rule works better then using the pulley. There is no guarantee it is centered using LS1howto's method.
Old Oct 10, 2010 | 10:52 AM
Damian's Avatar
LSX Mechanic
Most definitely not RTV. You're not working on an iron small block chevy. These motors do not go together like those. Use the aluminum/rubber gasket.
Old Oct 11, 2010 | 01:54 PM
some_punk's Avatar
does anyone have a picture of the locations of the spots to put the RTV stuff?
Old Oct 11, 2010 | 02:00 PM
blsnelling's Avatar
Just the two bottom corners, where the front cover, oil pan, and block all intersect.
Old Oct 13, 2010 | 09:00 PM
some_punk's Avatar
should there be any on the bottom of the timing cover gasket too? and will the ls1howto method of centering the timing cover be good enough?
Old Oct 14, 2010 | 01:53 AM
caseypryan's Avatar
this ^
Old Oct 14, 2010 | 10:18 PM
some_punk's Avatar
Originally Posted by caseypryan
this ^
What i am trying to ask is should there be any at the bottom between the timing cover gasket and the block and the pan.
Old Oct 15, 2010 | 07:35 AM
Gonoma's Avatar
he already answered that for you
Old Oct 15, 2010 | 10:36 AM
ND400's Avatar
Lay of the crack. I'd come there and sucker punch you myself. If you used RTV
Old Oct 15, 2010 | 11:02 AM
blsnelling's Avatar
What else can we tell you?
Old Oct 15, 2010 | 11:09 AM
Jim_PA's Avatar
Don't clean off the front of the block, the dirt marks made from the timing cover will allow you to re-install it without worrying about it being off-center
