Blown gaskets
Old Oct 10, 2010 | 09:55 PM
drummer_192's Avatar
Default Blown gaskets
my procharged ls1 last night blew a valve cover gasket, replaced it, test drove it and then it blew the PCV valve, replaced that and it continued to blow the PCV hose off the valve, zip-tied the valve to the hose and then it blew the new gasket, its blown twice now around #5 and #7 cylinders.......whats causing this? oil pressure is around 20-40 depending on RPM, and it wants to die when at idle, this is over my head. Any thoughts?
Old Oct 11, 2010 | 10:35 PM
massls1guy's Avatar
Sounds like you have boost going through the PCV system. I think a lot of people with a blower ditch the PCV system and just run a breather.
If you keep the PCV with boost I think you need one way check valves so vacuum can pull air but boost is blocked.
Old Oct 12, 2010 | 12:24 AM
SilverSS's Avatar
Blown ringlands.
Old Oct 12, 2010 | 05:22 PM
crainholio's Avatar
Originally Posted by SilverSS
Blown ringlands.
What he said. Excessive crankcase pressure seems to be causing your symptoms, the root cause is likely piston failure.
