camaro performance
Old Oct 12, 2010 | 06:18 PM
joker59's Avatar
Default camaro performance
Is it a good idea to put cam and heads in an automatic 98 Z28 with 128,000 miles. I'm going to put a cam, but not sure about heads. I'm thinking its too much work for an old engine.
Second question is, if I use Mopar combustion chamber cleaner would the engine lose compression? Thanks
Old Oct 12, 2010 | 08:56 PM
joker59's Avatar
anyone?
Old Oct 12, 2010 | 09:45 PM
King Nothing's Avatar
i did it at 169K and mine lasted . . . until i got stuck in a water puddle lol
btw what is mopar combustion chamber cleaner? is it like seafoam?
Old Oct 12, 2010 | 10:04 PM
SSmoken's Avatar
go for it man. i did my cam at about 135k and heads about a month ago at 142k.
Old Oct 12, 2010 | 10:09 PM
massls1guy's Avatar
I did H/C at 110k, now at about 176k. Once the old heads are off you can replace the lifters and lifter trays. And with new heads you have new valves, seals, springs and valve guides. I think it's a safer bet on a high mile motor than just doing the cam & springs.
You can also clean the pistons while its open and forget the engine cleaner.
Old Oct 13, 2010 | 02:08 AM
joker59's Avatar
Thanks guys, now its a question of, do I want that much power?
Old Oct 13, 2010 | 02:17 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Yes, you do. You wouldnt have asked about it in the first place if you didnt.
Old Oct 13, 2010 | 02:20 AM
01ssreda4's Avatar
Do it!!
Old Oct 13, 2010 | 02:50 AM
SSmoken's Avatar
sure you do. then after a year at the most, you'll want more. thats just how it works.
Old Oct 13, 2010 | 06:34 AM
crainholio's Avatar
If you have to ask, then you don't. Paint it pink, swap in a Prius rubber band and buy carbon credits.
Old Oct 13, 2010 | 09:17 AM
BlackScreaminMachine's Avatar
Internet Mechanic
All I say about Higher milage builds is that you need to be prepared that if you blew the motor that you MAY have to replace everyone of those expensive parts you just installed.
If a piston eats itself, rod gets thrown, debris in the oil or cyl. You can really trash stuff.
Old Oct 13, 2010 | 09:50 AM
slt200mph's Avatar
Go ahead and insall your heads and cam...I have had three different cams and heads on my ride...the last one was done at 130,000 miles and it now has 220,000 miles on it.
