P1637 code.... Scratching my head
Old Oct 13, 2010 | 07:39 PM
willystyle438's Avatar
Default P1637 code.... Scratching my head
Alright, I had my bottom end gone thru by LME out of Houston, Tx. (old motor was smoking like a chimney, but running fine) it is now a 347 forged bottom end. I installed motor back in car.
No lights on Dash. My car runs fine for about a mile then it sputters for about a 1/2 mile then runs fine again. Over and over again. Off and on. I checked all the grounds from the main harness, all the grounds are on the back of the heads bolted down and tight, i replaced the alternator and plug and i sure could use the feed back.
I had a real time scanner put on my car going down the road. All cylinders are firing and not missing & fuel pressure is good at 58psi.
P1637
Generator L-Terminal Circuit
Anyone?
Old Oct 13, 2010 | 08:13 PM
Darkman's Avatar
See attached
File Type: pdf
Old Oct 13, 2010 | 08:27 PM
Grassy azz.... Will preform tests tomorrow.
My O'lady is mad because i am drinking so much stressed out over something like this. She told me i can pull a motor and trans and put it back in with 2 bags of tools and a socket set and i can't even figure out a little miss.
I want to choke her. But that is the alcohol talking.
Old Oct 13, 2010 | 08:45 PM
SOMbitch's Avatar
Chill out and I bet is something simple...Just F***k the **** out of the OL'Lady and take out your frustation and you both win..... but what do I know I am divorced (and lovin it)... you'll figure it out..... BTW that exciter (sp) on the alt is EASY to damage....
The dashlights has me scratching my head but I would check the pcm connections first...
Old Oct 13, 2010 | 10:11 PM
What I meant to say was that there are no SES lights or anything throwning codes. That code doesn't throw a light.
Believe me, I will beat Momma up tonight (the good way).....
Old Oct 14, 2010 | 10:09 AM
Mguncowboy's Avatar
U drinking to much over this problem - now thats a joke, cuz anyone that knows you knows that you're always drinking to much. And you better hope momma dont see this post cuz she gonna kick yo *** if she does! LMAO.
Old Oct 14, 2010 | 01:58 PM
I Drink.... So.
And if she wants to kick my azz, she better bring some friends... I hope she does.
