Pushrod question for those running Morel lifters..
Old Oct 13, 2010 | 04:28 PM
Jonnie Bravo's Avatar
Default Pushrod question for those running Morel lifters..
Going to be installing them and some heads this weekend and already have an LG cam with 7.4 rods in there now. I know the preload on the lifters need to be .030-.050 and I'm curious what people are finding in the Morels v.s the stock lifters when it comes to pushrod length?
My car is a daily driver so I will be measuring and hopefully ordering the proper length Saturday afternoon, and I have done some searching and found a thread saying a guy measured his and they were .010 different. So I guess if the measurement is not too far off 7.4 is it o.k to run them for 3-4 days with the 7.4's until the proper length rods arrive?
Old Oct 14, 2010 | 04:34 AM
vettenuts's Avatar
I would not. The lifters are taller and require less preload, I think you will find the difference closer to 0.100" putting you around 7.300" based on my experience not accounting for the cam swap, which will change the numbers a bit closer to 7.325".
Old Oct 14, 2010 | 07:36 AM
WKMCD's Avatar
Agreed. I run their link bar lifters and they are about .050 taller.
That being said - measure.
Old Oct 14, 2010 | 11:10 AM
Thanks guy's I have the Comp adjustable pushrod so I can measure as it seems like a pretty easy process as from what I'm reading you just turn the cam until it's off the lifter, install the rod and torque the rocker and screw the rod out until it takes out the slack on the rocker, then add .050 for preload?
Although when I bought them they said preload needed to be .030-.050 for preload so I guess my question would be is it best to go with the .030 because the lifters are taller?
I really appreciate all the advice!
Old Oct 14, 2010 | 02:08 PM
vettenuts's Avatar
I had the best luck at the upper end and am currently set at 0.050" preload. I have written instructions for the pushrod if you need it. I don't torque to full 22 lb-ft when adjusting, too much needless loading of the aluminum thread in the head.
