best heads
Old Oct 13, 2010 | 09:43 PM
05gmc's Avatar
Default best heads
im builing a 6.2 iron block whats the best heads to run
Old Oct 13, 2010 | 10:30 PM
dwfronk's Avatar
Low compression or High Compression build? Need more specifics
Old Oct 13, 2010 | 10:34 PM
gateman's Avatar
AFR's, if you have the budget
Old Oct 13, 2010 | 10:43 PM
flintwrench69's Avatar
L92 or LS3.
Old Oct 13, 2010 | 11:01 PM
05gmc's Avatar
shooting for 11.5 cr
Old Oct 14, 2010 | 08:51 AM
Isolde's Avatar
MAST Motorsports LS3 heads are among the very best, in flow anyway. But the price reflects this. Probably because they're not just ported production heads, but all-new castings.
Old Oct 14, 2010 | 09:43 AM
Unertl42's Avatar
trick flow should be coming out with square port heads soon, I would wait and check them out
Old Oct 14, 2010 | 10:06 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Alot of suggestions in this thread with no information to base them on!
What are your plans for the car? Do you already have a camshaft or are you going to install one that is built for the heads? Naturally aspirated or power adder? What kind of vehicle is this going in? Is your 6.0L a flat-top or dished piston? What transmission, gear, stall, etc? Weight of vehicle?
These are just some of the questions you should be asked to answer before anybody makes a recommendation for you! If they don't ask, then they aren't going to give you good advice!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Oct 14, 2010 | 12:46 PM
ShevrolayZ28's Avatar
Take this guy's advice.
Old Oct 14, 2010 | 08:52 PM
'02 WS6's Avatar
Tony Mamo's worked over AFRs gets my vote.
Old Oct 14, 2010 | 10:03 PM
SOMbitch's Avatar
We are blessed there are many great choices... AFR, TFS, PI, PRC (proprietary) Mast etc....
