howards cams?
Old Oct 14, 2010 | 11:09 PM
stangtrader's Avatar
Default howards cams?
i did a search but didnt really find anything about there cams,was wondering if any one has used one of there cams and what they think of it?im looking at a certin cam from them (info below)and wanted to see what you guys think of these specs.i think this would be a good cam for a cam only car, i figured to go bigger than the tsp228r that i was looking at and this should have some driveability. i just dont want to buy a 228r and wish i went with a bigger cam
plus im going to continue using nitrous
thanks joe
Brand Howards Cams
Manufacturer's Part Number 190265
Part Type Camshafts
Product Line Howards Cams Max Effort Camshafts
Summit Racing Part Number HRS-190265
Cam Style Hydraulic roller tappet
Basic Operating RPM Range 2,800-7,200
Intake Duration at 050 inch Lift 236
Exhaust Duration at 050 inch Lift 242
Duration at 050 inch Lift 236 int./242 exh.
Advertised Intake Duration 287
Advertised Exhaust Duration 289
Advertised Duration 287 int./289 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.612 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.612 in.
Valve Lift with Factory Rocker Arm Ratio 0.612 int./0.612 exh.
Lobe Separation (degrees) 113
Computer-Controlled Compatible No
Valve Springs Required Yes
Camshaft Manufacturers Description Large cubic inch, race-only applications.
Quantity Sold individually.
Howards Cams Max Effort camshafts are race-only profile cams that use the highest grade race-quality billets available. All Howards Cams camshafts are 100 percent Rockwell-checked and Parkerized to ensure the highest quality control standards available anywhere. These Max Effort camshafts are computer-designed and dyno and track-proven to produce the highest horsepower and torque for a given engine combination. Howards Cams has numerous profiles available. All Howards Cams are packaged and shipped in unique, hard, high-impact plastic reusable cases. This ensures that the high-quality camshafts that went into the cases are delivered in the same condition that they were in when they were packed.
Old Oct 15, 2010 | 09:29 AM
Isolde's Avatar
I used one of their cams in an L98. That's not LSx, but still, the quality seemed good, the results were very good, and I'd do it again.
Old Oct 15, 2010 | 12:09 PM
cool thanks for the reply,cam specs are about the same as thunders raptr
cam,but 113lsa instead of 111lsa and lift is slighty diff. can any one tell me if pac 1518 will be fine with this cam?
thanks joe
Old Oct 15, 2010 | 02:42 PM
ryarbrough's Avatar
"Computer-Controlled Compatible No"
You might want to make sure it's got provisions for the cam sensor to read cam position.
Old Oct 15, 2010 | 06:49 PM
thats a very good point it most likely does,i know alot of the cams for 5.0s on summits website say the same thing never had any problems.
Old Oct 16, 2010 | 08:34 PM
MPFD's Avatar
11 Second Truck Club
My current cam was ground by Howards and I'm happy with it.
Old Oct 17, 2010 | 11:50 AM
MPFD if you don't mind me asking how much did they charge you? At the moment I'm waiting to hear back about the current cam choice. May just do a custom ground if it comes down to it
Old Oct 17, 2010 | 10:01 PM
MPFD's Avatar
My current is the Patriot Cam, Howards grinds it for them...
 Michael S. Palmer
