milling 317 ?
Old Oct 17, 2010 | 04:02 AM
taman86's Avatar
Default milling 317 ?
hey guys, got a couple questions, maybe you can help me.
what is the most i can mill a set of aluminum 317 heads?
how much do i need to mill to say achieve 65cc or even 63cc?
i have had a set forever now that i keep moving with me and they are just attracting dust. i bought them from a buddy of mine a couple years ago in the attempt to build a FI setup but the project never took it. i cant seem to sell them so im thinking that maybe im gunna build them. get a good port job on them, and a nice valvetrain and do a head swap down the road. that does sound more attainable then a 5 grand FI setup.
Old Oct 17, 2010 | 07:21 AM
masterz28's Avatar
my friend milled his .015 for the Ms3 cam. I heard that was the most so far around.020".
Old Oct 17, 2010 | 03:27 PM
taman86's Avatar
milling that much would bring the compression to what?
Old Oct 17, 2010 | 10:02 PM
Damian's Avatar
LSX Mechanic
Every .006 you take off is 1cc. So if you cut .030 off, that would drop the heads ~5cc but I think they're in the 72cc range in stock form, so you'd have to cut the **** out of them to achieve 63-65cc. Or cut .030, then run a thinner gasket.
Old Oct 17, 2010 | 11:38 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
This...
Old Oct 18, 2010 | 01:34 AM
taman86's Avatar
alright thanx for the help. would cutting them .030 be safe enough to run. running the heads with that much milled, i would have to run 7.35" pushrods to maintain correct valvetrain geometry right?
Old Oct 18, 2010 | 08:22 AM
masterz28's Avatar
^Somewhat, its best to measure.
Old Oct 18, 2010 | 08:46 AM
5.3LJimmy's Avatar
You can mill them .040 without having intake gasket sealing issues. If you did this and ran an 0.040 gasket you would have about 10.9:1 CR. Personally I would just ditch the 317's and pick up a set of 243/799 castings. If the 317's were already ported then it would be worth it to have them milled to work for you, but there are better options to start from scratch with.
Old Oct 18, 2010 | 09:58 AM
taman86's Avatar
why, the 317's flow the same as 243's. the only difference being that the 317's have a 72cc combustion chamber and the 243/799 have a 63cc combustion chamber.
Old Oct 18, 2010 | 10:10 AM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
That is true, but at the point that you mill that much and run the thinner gasket you lose a lot of piston to valve clearance. So it also depends a lot on what cam you are looking to run. The 243 head will acheive the desired compression ratio without having to lose as much clearance so you can run a larger cam.
Old Oct 18, 2010 | 10:59 AM
5.3LJimmy's Avatar
^^^^that is why^^^^. You are milling the heads as much as you can and running a thinner gasket to gain almost no compression over the stock heads. So I would not invest that much time and money into the 317 heads when there are much better options for a very reasonable price.
Old Oct 18, 2010 | 11:12 PM
taman86's Avatar
oooohhhhhhhhhh i see, thanx alot for the help
