My Head/Cam Install
Old Nov 1, 2010 | 10:35 AM
splitfinger09's Avatar
Do I need new lifter trays? Also what is the best cam and lifter lube you can buy locally?
Old Nov 1, 2010 | 05:03 PM
mike.d's Avatar
grind out some hemastats to hold bolt for oil pick up tube works great
Old Nov 1, 2010 | 05:46 PM
djfury05's Avatar
You don't NEED new lifter trays, but while your there and they're pretty cheap (around $35 for 4 LS2 lifter trays) you might as well. I saw some in the classifieds the other day for $12 shipped for all 4.
As far as the LS6 Valley cover eliminating oil consumption.. I put one on and I am still having oil in my intake. So I got a catch can to fix that problem now.
Old Nov 6, 2010 | 10:49 PM
Update. I got the motor mounts installed. It really wasnt that hard with the engine stripped down as much as it is at this point. The scissor jack method to getting the pass bolt back in is great! Thank you cyberkill! I got the new trunions installed with just a few tools that most of us have. Its a great upgrade to the stock rockers and relitivaly cheap. Thank you bene! My svo green tops just came in so all im waiting for now is the heads and the pushrods. I have no idea when they will come in but im hoping soon. I ordered them on the 4th of October...
Old Nov 6, 2010 | 10:50 PM
not exactly sure what this means?
Old Nov 10, 2010 | 01:59 PM
Okay question. Ive seen a few different methods to cleaning the old head gasket off the block. I did the ice scraper method, but there still seems to be alot of gasket left and there are spots where I can see the bare metal. Do I need to take a razor or some sand paper to it to get it cleaner?
Old Nov 10, 2010 | 02:43 PM
chevboy28's Avatar
razor blade for sure and keep it flat
Old Nov 29, 2010 | 10:30 AM
Okay so I got everything installed and I went to start it last night and it just wont stay runnin. Also my tach is not working. Basically it will start and I will try to give a little gas but not much really happens and it just dies. Oil pressure is good and everything seems to sound ok, but it just wont stay running. I realize this could be number of different problems, but just looking for some advice where to start trouble shooting. Also the computer has a mail order tune for my setup. Thanks for the help everyone.
Old Nov 29, 2010 | 11:54 AM
King Nothing's Avatar
you need a tune. i wouldn't even keep it running with new heads, cam and injectors at all. trailer it to your tuner and have them tune it so you don't do something bad to the engine. btw clean *** engine bay!!!!!!! has the car ever been driven j/k
Old Nov 29, 2010 | 12:16 PM
disc0monkey's Avatar
what do you do to keep your motor so clean?!?
Old Nov 29, 2010 | 12:37 PM
Even with the mail order tune? Brett at xp racing (my tuner) said that it should be fine to drive and would actually be good to get any mechanical issues out of the way. Ive always had it either AZ or CA so not to hard to keep it clean.
Old Nov 29, 2010 | 01:52 PM
  #32
11seccamaro's Avatar
If your tach isnt working at all and it wont run maybe crankshaft position sensor is bad or not plugged in? Thats just an easy check down by the starter..... if thats all fine then I agree you need a tune. I just did a whole motor swap with new cam and heads and my car barely idles in closed loop, def trailor it to the tune shop
Old Nov 29, 2010 | 09:04 PM
  #33
on larger injectors???? i don't agree with that but i'm not a tuner . . . bottom line is it's your car and you need to make that call but listen to the advice of others.
Old Nov 29, 2010 | 10:17 PM
  #34
Whiteaw57's Avatar
With new injectors you need a hand on tune, thats not to mention the cam and heads
Old Nov 29, 2010 | 10:41 PM
  #35
Texhotrod593's Avatar
ok dude>>>if you want to go ahead and start it and let it warm up a little it would hurt it really AT IDLE. Keep it under 1500 rpm...at that rpm the new heads,cam etc wont makemuch difference. Now to do this you need to swap your stock injectors in because you do not have a tune that scaled these injectors. so if you want to warm it up....swap injectors back to stock. Swap the to your greens when you go get it tuned
Old Nov 30, 2010 | 01:16 AM
  #36
GIVE EM' THE BIRD's Avatar
yes
Injectors MUST be tuned by hand according to... well.... everyone
Old Nov 30, 2010 | 06:38 PM
  #37
Originally Posted by GIVE EM' THE BIRD
yes
ok I will def not drive it on the new green top injectors. However if I swap the stockers back in will I be able to drive it? Or should I just trailor it down to the tune shop? Its about 2.5 hours from my house. Also one more question. You all seem very knowledgable so would you look at this thread tnd tell me if you agree with what im about to do. https://ls1tech.com/forums/generatio...ead-bolts.html thanks for all the help.
Old Nov 30, 2010 | 09:31 PM
  #38
you should be able to drive it around a little but really not on a 2.5hr drive. all that money you just put into it...im sure you dont wanna screw that up because you cant find a way to haul it to the tuner right now . like i said b4, swap the injectors to warm it up and check for leaks etc but please for the sake of god, dont drive it that far. as for the arp bolts....i say swap them out one by one but do it in the torque sequence. if you do it that way you should be golden. I would go ahead and and drain the the coolant to be safe, but you shouldnt get any seepage at all. think about it man...you have the head torqued and taking one bolt out at a time. you should be just fine
Old Dec 1, 2010 | 10:57 AM
  #39
your welcome bud, rather help someone out than watch them hurt their engine unintentionally and for the ARP bolts, i don't know crap on that subject thats where my knowledge stops lol good luck with it all and post up the vid of you running it at the track and idling!
Old Mar 18, 2011 | 08:20 PM
  #40
Okay I finally finished everything up and swapped back to the stock injectors. The car just will not stay running. It starts up just fine, but then it just dies on me. I had a mail order tune done for the new injectors. Would this affect the car while runnning stock injectors. Basically I just wanna get the car started so I can work out any mechanical issues if any. Thanks for the help!
