Accessory drive compatability in a LS6
Old Oct 19, 2010 | 10:09 PM
LS3"'s Avatar
Default Accessory drive compatability in a LS6
Hello LStech,
Will the engine accessories [brackets and all] from a 4th gen Fbody [98-02] bolt right on to a LS6 block? Will they still be in the original 4th gen Fbody accessory configuration? Does the LS6 block possess the right fastening points to accomplish this?
If not, are there any companies that specialize in custom accessory kits that enable the LS6 and 4th gen Fbody accessory set to work in the 4th gen Fbody?
Old Oct 19, 2010 | 11:46 PM
NVR_SPDS's Avatar
Yes, everything is identical. LS6 blocks were used in some 01-02 f-bodys from the factory.
Old Oct 20, 2010 | 12:57 AM
Arc00TA's Avatar
Sure will. Everything will match. If you buy a used block and it has a pulley on it make sure it is an f-body pulley as they are not interchangeable.
Old Oct 20, 2010 | 05:54 AM
01ssreda4's Avatar
Like stated, its identical.
