Patriot Or PRC Springs
Open to any other options too.
If someone spent some time with both springs on a spintron the decision would be a no-brainer. The new PRC spring is a large step in development past the gold/platinum stuff.
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
https://ls1tech.com/forums/generatio...ls3-heads.html
edit* oops I just realized you wanted to go with a dual spring. Either way the 1518 or the pac dual will work fine. Id stick with the 1518's but thats jmo...
For those looking for the cliff's notes, I measured the installed height of the Patriot Xtreme springs on my 100% new GM LS3 heads and found that their installed height measured at about 1.750"... low enough to put me into coil bind with the .650 cam I intended to run.
After being told by countless people that the patriots were the spring to get, I called TSP and they mentioned that I wasn't the first person to make this discovery, and said he was sure that the TSPs would install at the proper height. I got the TSPs and they installed at just a few thousands under 1.8", which left ample space for my .650 cam.
Makes me wonder how many people actually check these things before they install them.
It also makes me understand why I see so many valve spring failure threads on here.
