Help needed with Crank Position Sensor
Old Nov 3, 2010 | 10:48 AM
w06gto's Avatar
Originally Posted by RsSean
Are you getting crank position circuit code? I just went thur this on my car, pull the number one plug ground it have someone turn the motor over. If you do not have spark you have the 58x reluctor wheel. LPE sell the coinvertor box that you need to wire along with that you will need to buy the LS3 front timing cover, LS3 timing set with cam sprocket, and new cam position sensor.
I bought the rotating assembly from Texas speed and they are sure it is 24x reluctor wheel and i got the code p0336.
Maybe i will try that this weekend but i doubt that is it.
Old Nov 3, 2010 | 10:53 AM
1lejohn's Avatar
Check the connector on the harness. I've had them go bad. The wire will actually break inside the insulation, making contact sometimes and then not.
Old Nov 3, 2010 | 11:08 AM
w06gto's Avatar
Do you mean the connector going to the sensor or the connector going to the pcm?
Old Nov 3, 2010 | 12:12 PM
sman's Avatar
I had the connector go bad to the sensor on my car, only ran about half the time, and the tach kept going in and out. Pulled the connector apart and repined it, still working, 2 years later.
Old Nov 3, 2010 | 12:51 PM
w06gto's Avatar
sman I will double check the connector i haven't really looked at it.
Did you get the code for the crank position sensor?
Old Nov 6, 2010 | 09:55 AM
w06gto's Avatar
Bump for the weekend crowd!!!!!!!
Old Nov 8, 2010 | 02:13 PM
w06gto's Avatar
Took some shots of the reluctor wheel just to confirm that it is a 24X
Attached Thumbnails Help needed with Crank Position Sensor-img_20101107_164327.jpg   Help needed with Crank Position Sensor-img_20101107_164335.jpg   Help needed with Crank Position Sensor-img_20101107_164343.jpg
Old Nov 8, 2010 | 02:17 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
That is definitely a 24X wheel!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Nov 9, 2010 | 01:43 PM
w06gto's Avatar
Matt Thanks for the conformation !!
I never doubted you guys!
Old Nov 9, 2010 | 02:30 PM
w06gto's Avatar
Bump added video of car!
Old Nov 9, 2010 | 05:56 PM
KTMR's Avatar
I'm going through the same problem!... So far we have swapped out 2 sensors, 2 pcm's and checked the reluctor to p/up gap. I've gone over the sensor voltages and the only thing that seems incorrect is the cam sensor volts are @ 12.84v where the table shows it should be 5v... The code that keeps coming up is P0103 (crankshaft position sensor performance A)
I clear and it re-appears but not always straight away.
I have been told that a CASE relearn will fix but so far no success...
Can you verify if your cam volts and crank sensor volts are correct? ie 5volts/12volts
Thanks
mike
Old Nov 9, 2010 | 07:23 PM
  #32
Steve01SS's Avatar
You reattach all the grounds to the block? like on the backside of the head?
Old Nov 9, 2010 | 08:26 PM
  #33
joecar's Avatar
You need to find someone who has (and knows how to use) an automotive oscilloscope, to look at the CKP and CMP waveforms (referenced to #1 ignition primary/secondary) to see if they are phased correctly and have the correct shape/amplitude.
Old Nov 10, 2010 | 08:19 AM
  #34
w06gto's Avatar
Thanks
mike
Mike on which colored wire?
i took some readings with my volt meter and wrote down the voltage as soon as i get out of work i will post it up
Old Nov 10, 2010 | 08:20 AM
  #35
w06gto's Avatar
Yep all grounds accounted for i also used a test light to verify that the ground was good!
Old Nov 10, 2010 | 08:23 AM
  #36
w06gto's Avatar
Yea im trying to fix it my self and save money and my pride this is the first car i have not been able to fix.
but i might take it to a shop if they are open tommrow!
Old Nov 10, 2010 | 10:53 AM
  #37
joecar's Avatar
Ask the shop to show you their oscilloscope and to show you any crank/cam waveforms they captured from other vehicles...
if they can't do that, or if the waveforms have poor resolution (i.e. you can't measure the time between crank pulses on the waveform), then goto another shop.
Old Nov 10, 2010 | 02:01 PM
  #38
joecar's Avatar
This is what the 24x/1x CKP/CMP waveforms should look like (attached).
This waveform was captured using a Picoscope which is a deep buffer high resolution automotive oscilloscope.
I borrowed this from the Autonerdz forum (I annotated it to show the relationships between the waveforms).
Attached Thumbnails Help needed with Crank Position Sensor-ckp_cmp_waveform_relationship_001.gif
Old Nov 10, 2010 | 02:15 PM
  #39
w06gto's Avatar
I dont really know what im looking at, so i think i will take it to a pro the shop im taking it to should have a GM TECH 2 and the owner is a GM Master tech so i hope i will be in good hands. Thanks for the info i will def. tell him about it!
Old Nov 30, 2010 | 02:53 PM
  #40
Did you ever get this straightened out??
__________________
