g5x3 hp numbers
Old Oct 25, 2010 | 10:48 AM
badazz99ss's Avatar
Default g5x3 hp numbers
Hey wussup guys I have a quick question. In the next week im getting a g5x3 cam installed on my 99ss. It has full exhaust cold air 3.73 gears ls6 intake with 28lb injectors walbro 255 fuel pump springs double roller etc. stock heads and it is a 6spd and 100shot but wont be spraying yet I just want to see the n/a hp. What hp numbers would you guys say i should expect. And what to expect on the 100shot also. Thanks alot
Old Oct 25, 2010 | 04:09 PM
RJB01camaross's Avatar
LS6 Intake and no UDP will hold your numbers back a bit, but N/A I would say around 390-400rwhp and on the juice around 480-500rwhp.
Old Oct 25, 2010 | 05:16 PM
badazz99ss's Avatar
Yea thats kinda what i was thinking i just wanted to make at least 400rwhp for now n/a until i bought my trickflow heads and fast intake around income tax time
Old Oct 25, 2010 | 07:00 PM
mike c.'s Avatar
You need a fast intake bad. Try to get a used 90-92mm over the 102mm. worth 20hp and being used,you save money. Power numbers is what ever the dyno feels that day. In the past i did 400hp on a jet and with the same set up did 370hp on a mustang dyno. Now i'm 530hp on that same stang dyno.
Old Nov 1, 2010 | 09:36 AM
badazz99ss's Avatar
So what was your numbers after the fast intake install
Old Nov 2, 2010 | 12:55 AM
tnmotown's Avatar
I say over 400rwhp for sure. On my old '01 z28 I also had full bolt-ons (also had an UD pulley which I see you don't have) and with a SD tune it made 421rwhp/390rwtq. Had 4.10 gears and car was a blast to drive on the street. Good luck and have fun
Old Nov 4, 2010 | 12:04 PM
badazz99ss's Avatar
yea i would probably be getting a ud pulley because it seems everybody says I should consider one Im guessing they help out thanks alot.
Old Nov 4, 2010 | 07:54 PM
raymond mckinney's Avatar
I have the cam in my vette with afr 205's and a ls6 intake it makes 455 wheel and runs mid 120 mph traps.
Old Nov 5, 2010 | 11:15 AM
badazz99ss's Avatar
Smile
cool I was considering the same head setup it was either afr 205 or trickflow 215's but Ive heard afr is releasing their new 210 cc head I might just wait to see what those are about. What injectors are you running with that setup.
