Cam question?
Old Oct 25, 2010 | 08:28 PM
Justins00ss's Avatar
Default Cam question?
Ok so here is the deal. My buddy is giving me his cam out of his motor. Now keep in mind this is a mild cam for his setup and was DD it. Now I know in my car its going to be more aggressive but that doesnt bother me.
His cam which cam out of a 408. 236/240 600/600 on a 113 plus 4. Now my plan is to try to get a set of patriot 5.3 heads and bump the compression up to 10.75 or 11.0. And if I cant get the heads right away I will swap in a set of his low milage dual gold valvesprings good for 660 lift.
So do you guys think this thing will work out all right and what should I expect. I do plan on getting a FAST setup eventually too.
The car now has a 224/224 563/563 112 with a ls6 intake and pacesetter longtubes and a 4.11 gear.
Old Oct 26, 2010 | 12:20 AM
01ssreda4's Avatar
I think you are about to push your powerband way up from where it is now. Other then that, go for it if thats what you want.
