Any interest in new GM LS HD Rockers ??
Old 10-26-2010, 03:48 PM
LS1TECH Sponsor
Carshopinc.com's Avatar
Default Any interest in new GM LS HD Rockers ??
Just a post to gauge interest and or information on the value of this.
We have access to a bunch of these. BRAND NEW... GM oem supplier
USA MADE .. $189.00 set... 175.00 ea for 2 sets
I have converted the old style rockers with Comp Cams trunion kits,
and this would seem to be a better option.
NEW GM ROLLER ROCKER ARMS LS1 LS2 LS 6
FITS 5.3L 5.7L 6.0L
GENERATION III ENGINES
SET OF 16
REDESIGNED HEAVY DUTY BIG DIAMETER ROLLER BEARING
NO NEED TO REPLACE FACTORY SMALL ROLLERS WITH
DIFFICULT TO INSTALL AFTERMARKET REPALEMENT TRUNIONS
MADE IN USA
FULL OIL FLOW UNSHIELDED ROLLER BEARINGS
ALLOWS HOT OIL TO ESCAPE AND BE REPLACED
OIL GETS IN AND OIL GETS OUT
360 DEGREE FULL LIFT TRUNION SHAFT.
NOT RESRICTED LIKE OEM, WORKS WITH HIGH LIFT CAMS
NEW ATTACHING HARDWARE INCLUDED
DID I SAY, MADE IN USA ??
Old 10-26-2010, 08:19 PM
Slow 346's Avatar
Interesting.....
Old 10-27-2010, 12:29 AM
01ssreda4's Avatar
Seems reasonable, just keep in mind you are creeping up on about half the price of full rollers. People aren't going to spend too much and still have stock rockers.
Old 10-27-2010, 07:19 AM
chris-m's Avatar
can you ship to the uk as i might be interested in a set of these, or upgrading my own with one of the kits if not.
cheers
Old 10-27-2010, 09:32 AM
LSX Mechanic
Damian's Avatar
Are they doing this for the L92/LS3 stuff too?
Old 10-27-2010, 11:16 AM
LS1-450's Avatar
Not too bad for having included upgraded trunions.
Old 10-27-2010, 06:54 PM
87gtNOS's Avatar
Are these just bolt on and go? No need to change pushrod length?
Old 10-28-2010, 11:47 AM
LS1TECH Sponsor
Thanks for the responses .... Yes thay are boltin and go deals...
I will check on the L92 LS3 offsets.. But not sure if they already have the big bearings.. any help on that ??
Glad to Ship UK... $40.00 US Postal Priority International
Have a link for purchase.... We accept Paypal too...
http://carshop.carshopinc.com/produc...47/SSILS/HP/RA
Old 10-28-2010, 12:20 PM
sjsingle1's Avatar
those look sweeeeeet
Old 10-28-2010, 12:57 PM
thunderstruck507's Avatar
seems like a decent deal to me
Old 10-28-2010, 03:07 PM
chris-m's Avatar
very interested in a set if i can get them shipped!
Old 10-28-2010, 03:12 PM
lubelizard's Avatar
This is an OEM supplier manufacturing the rocker arms and then installing an aftermarket trunion, or is/will this be an OEM GM item? I'd like to know who makes them, quality and comparison to stockers with the Comp upgrade before purchasing. I'd be more than willing to buy a set after learning more about them. Thanks.
Old 10-28-2010, 05:22 PM
LS1TECH Sponsor
It is an OEM USA supplier... designed as a replacement for the failue prone stockers..
Thanks Tim
Old 10-29-2010, 02:10 PM
chris-m's Avatar
i'm in, thanks tim, paypal cash sent just now! looking forward to seeing these land here!
thanks
Old 10-29-2010, 03:32 PM
LS6
LS6's Avatar
Very nice product
Old 10-29-2010, 04:47 PM
LS1TECH Sponsor
got it.... Will mail out a set Saturday.... Cheers Tim
Old 10-30-2010, 12:15 AM
01ssreda4's Avatar
Thanks Tim
So are you saying stockers are unreliable? I was under the impression that it was very very limited cases of stock rockers failing.
Old 10-30-2010, 04:20 AM
LSPerformance's Avatar
Is there anything "HD" about the rocker body itself? (material, cross-section) or is the improvement just in the bearing area?
Thanks
Old 10-30-2010, 08:30 AM
LS1-450's Avatar
I realize that this question was not addressed to me, but wanted to add my experience. Have had a rocker arm needle bearing retainer pop off on my stock rockers while using a med-high lift cam w/ heavier dual springs. When the retainer pops off, the needle bearings come out & get into the heads & oil pan. I have a different solution to the problem. However, the best solution is offered in the aftermarket trunnion upgrade offered here, from the sponsor & by other sponsors. IMO, the problem is few & far between only when relating the problem to stock lift/spring rate cams. Higher lift/heavier spring cams are more susceptible to the problem.
Old 10-30-2010, 09:44 AM
mtuggle86's Avatar
Do you offer any type of trade in on the stock rockers?
Quick Reply: Any interest in new GM LS HD Rockers ??
