prc 2.5 5.3 59cc ptv?
Old 10-28-2010, 02:09 PM
BIGB4015's Avatar
Default prc 2.5 5.3 59cc ptv?
Anyone know if the prc 2.5 5.3 heads milled to 59cc will clear the tsp 228r camshaft? If so what kind of rwhp could I expect?
Old 10-28-2010, 02:25 PM
camz28arro's Avatar
Supposidly from what I've come across on here, with the stock gm gasket it should fit but any bigger will be getting very close. Still measure though.
Old 10-28-2010, 10:44 PM
12 Second Truck Club
06tx4.8's Avatar
i have the PRC stg 2.5 milled to 60cc, and im running the Torquer V2...232/234 595/598 112
Old 10-28-2010, 10:52 PM
01ssreda4's Avatar
Any way to place the head first, measure, then decide how much to mill? Unless you are buying them already milled.
Old 10-29-2010, 11:31 AM
BIGB4015's Avatar
I was gonna order the heads milled. Maybe Tsp will chime in.
Old 10-29-2010, 11:40 AM
Always2Slow's Avatar
i would say you could get away with doing a 59cc with that cam and those heads
Old 10-29-2010, 03:33 PM
bww3588's Avatar
best way to order them milled is to use your stock heads and check your PTV, then use that to decide how much to mill and still be safe.
