Top end tap?
I have a top end tap, did a wot run the other day when I let off it was fine turned off the road it started tapping bad, loss of power, and surging. Shut her down and got her home and she has a light top end tap its not that bad but its missing not a dead miss like a dead cylinder, and its all on the pass side it seems. I did a compression and leak down check on the pass side 160 across the board, pulled the rockers and pushrods and their straight. So today I am gonna pull the drivers side and check it to make sure no bent pushrods or broke rockers, but after this I am lost. Any suggestions from you guys to narrow it down.
