main caps help
Old Nov 6, 2010 | 02:22 AM
asianredneck's Avatar
Default main caps help
Ok we took the main caps off the ls1 motor and well we forgot which cap goes to which crank number. Does it matter ? How freely should the crank turn with pistons and rods installed.
Old Nov 6, 2010 | 07:39 AM
O2Form's Avatar
Yeah its important..........better figure out where they belong or go get it align bored! the crank should spin free like a fine watch!
Old Nov 6, 2010 | 07:49 AM
01ssreda4's Avatar
The numbers are printed/indented on them. 1 through 5.
Old Nov 6, 2010 | 01:30 PM
are they indented on the main caps? What order is the crank from front to rear?
Old Nov 6, 2010 | 01:38 PM
BarneyMobile's Avatar
Cap #1 would be front end of the block, keep in mind, caps 1 through 4 face the same direction, #5 faces the opposite way.
Old Nov 6, 2010 | 01:43 PM
01ssreda4's Avatar
^^^he is right...
Old Nov 6, 2010 | 01:46 PM
thanks, Can I reuse the main cap bolts?
Old Nov 6, 2010 | 04:27 PM
O2Form's Avatar
yes you can
Old Nov 7, 2010 | 05:25 PM
anyone have the sequence you need to torque the main caps?
