lq9 how much should i pay?
Old School Heavy
Did you have to flycut the LQ4 pistons? I know the center of these pistons are dished but the edges come pretty close to the valves. My L92's are milled .030".
I cant find any LQ9s that cheap on ebay, even from LKQ. Seems like the LQ4's are going for $1000+ with 70k - 180k miles.
I have seen a lot of them go on craigs list for around 500 to 800,with 60k on them and up,scoggin dickey sell the factory blocks,for 754.85,if I can't find something local I think I'm just gonna order one and build it,I'm sure something will pop up in my area soon,
the ly6 is like a newer version of the lq9. has a cast iron block. l92 aluminum heads. 9.6:1 compression. i was told the l92 heads flow better than ported 243s. With the right cam, these l92s are supposed to make greaT power but it can be a little harder to pick put the right cam that suits them. If u already have ported 243s, i would probably consider keeping them since u can re use your intake,rails,injectors,tb,etc. most of these items would have to be changed if u are going the l92 ROUTE.
