I've gotten it apart, now the fun begins...
Moderator
Forged pistons would be a good idea. I really like the Probe FPS pistons (P2600F-003) as a good budget NA piston. They're light, strong, and cheap. Plus torque plate honing the block out to a 3.902" bore will correct the bore geometry, help seal better, and translate into a little more power. The stock bore geometry is absolute crap. With a set of Perfect Circle file fit rings (41850CP-010), you're only in the hole about $500 in parts, plus machining costs (hone and balance).
Quick update: I finally got the GM Front drive setup (PN 19155067) and noticed one thing right off: on the instruction sheet, there is a part number for the same setup without the AC setup. The kit PN given was 19257325. I did a quick search on Google and didn't find squat. However, you never know. This could be a new item from GM, aimed at folks like me who run older cars W/O AC.
Anyway, I got the parts put on the engine with a minimum of fuss, and set aside the items I didn't use (AC Pump, belt, bracket, tensioner, and bolts) to sell at a later date. Below is a set of pics showing the engine before the accessory drive was added. I'll come back with new pics showing after shots.
![](http://rms.silverpen.org/e1.jpg)
The second pic is for people who've been told that the Corvette Batwing Oil Pan won't fit in a 2nd Gen TA. Main points:
![](http://rms.silverpen.org/oilpan.jpg)
Now, the last bits remaining before this beast hits the road: new high-pressure power steering hose (suggestions, anyone?), wiring the alternator and cooling fans, and welding in the rest of the exhaust. Woo Hoo!
- The transmission is in the stock location. No mods to the cross member, or drive shaft.
- I used Moroso early Chevy weld-in frame mounts, combined with LS1 conversion bolt-on mounts for the engine (see pic above).
- The original oil drain location (red arrow, below) is about 1/2 from the frame, once the engine was dropped in.
- I filed another spot flat, and tapped it for second drain plug (yellow arrow).
- Works beautifully.
