Which heads for new setup...
Old Nov 9, 2010 | 01:51 PM
JJ 86's Avatar
Default Which heads for new setup...
I'm planing my winter mods. I'm looking to pick up TSP Torquer V2 cam along with the basic parts with any cam swap. I want to do heads as well but not sure which heads will give the best bang for the money. Should I go for a set of milled and ported 5.3 heads or TSP stage II LS6 heads? Car is not a daily driver and will very rarely see the track. I'm looking to pick up hp under the curve and not so much top end hp. Current mods are vararam, lt headers, and fast 78mm intake. Car is 98 mn6 vette. Any ideas?
Old Nov 9, 2010 | 01:57 PM
JJ 86's Avatar
Winter mod list so far:
TSP head cam pkg (torquer V2 w/ stage 2 5.3 heads)
Ported LS6 oil pump
new pushrods
Dual Springs
Maybe underdrive pulley
LS7 lifters
42 lb injectors
Should this setup give me what I'm looking for? Hopefully, 430-440 rwhp/tq
Old Nov 9, 2010 | 04:51 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
The stage 2.5 ls6 heads I prefer a little bit over the 5.3l heads, but for the money the 5.3l heads are really hard to beat. You might also consider the PRC 215 heads. The aftermarket casting 215 heads are a little bit more $$ but they have some flow & compression advantages that make for some big power increases over stock GM castings.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Nov 9, 2010 | 05:17 PM
DaveX's Avatar
Those 215 heads look nice, wish I had those in place of my Darts.
Old Nov 9, 2010 | 05:39 PM
garygnu's Avatar
the ls6 stage 1 head flows about the same,and is $100 less.
