Cam questions
Old Nov 17, 2010 | 02:22 PM
krislem1990's Avatar
Default Cam questions
i want a big lopey cam. but would i have to change anything else out? or is it jus a swap? i have a 2000 SS M6. i jus love the sound when a car lopes and i want it badly! haha
Old Nov 17, 2010 | 02:28 PM
CamanLS1's Avatar
The minimum you are going to have to do is at least valve springs and pushrods. Texas speed has packages available for $530 right now for everything you need to do the swap. But then of course there is the "well since Im in there, I might as well do this" factor.
Old Nov 17, 2010 | 03:01 PM
haha i know it will end up happening but i want that to start out with. what size cam do i go with beings i want the lope. idk wat size would be best any ideas?
Old Nov 17, 2010 | 03:18 PM
CamanLS1's Avatar
Its not necessarily the size that gets the lope, its the LSA. You want something in the 112 or lower range. Since youre not going for all out power, you can go with TSP 228/228 cam. Use the link below, and use the down arrow to put in the 228 cam. They are on sale for $50 off.
http://texas-speed.com/shop/item.asp...d=174&catid=49
Old Nov 17, 2010 | 03:21 PM
well i also want power but i have to have that lope. what will i gain with this cam?
Old Nov 17, 2010 | 03:34 PM
CamanLS1's Avatar
Prolly see about 30-40 with that cam with a tune. If you want more power with serious lope, get the MS3 or Torquer v2. Those will net you closer to 50ish. Theres a lot of dyno information on this site. Just search the cam you want it should pull up some useful info. You can do the same on youtube to hear what each cam sounds like.
Old Nov 17, 2010 | 04:19 PM
garygnu's Avatar
the right exhaust and tune can give the motor that mean muscle car sound.match the cam to work with you tranny and rear gears.the LSA will effect how your cam lopes.look at the TSP cam kits cam,valve springs,and harden push rods.a ms3 will fit .
Old Nov 17, 2010 | 10:21 PM
i dont really know much about cam work. i am an infantryman i never really had time to work on a car like i wanted to. i need to know wat would be the best sounding cam to put into my car and that will give me a good amount of hp also. it doesnt really matter the cost. i can spend about a grand i guess on a good cam. i jus got to have that lope. give me some names of some cams if yall can that would be a great help
Old Nov 17, 2010 | 10:55 PM
blazer427X3's Avatar
I'm running a TSP 233/239, 595/605 on a 112 LSA. It pulls like crazy at 3,500 and has a nice lopey idle.
I would give the guys at TSP a call and tell them what your goals for the car are. They can recommend a cam package that should make you happy.
Thank You for serving.
Blazer
19E, 19K
3/163 ACR (long ago)
Old Nov 18, 2010 | 12:13 AM
Whiteaw57's Avatar
233/239 ALL THE WAY buddy made 403hp cam only with it on a 114 LSA i can't imagine how good it would sound on a 112
If I knew how to get a vid on here id post one so you could hear it. I feel like that cam is the perfect midrange cam. It sounds great Drives great with stock gearing pulls like a **** through the whole rpm band and you could drive the thing across the country and not know its cammed unless you pull up to a stoplight
Old Nov 18, 2010 | 12:18 AM
ok wats the difference between a 114 LSA and a 112? and i want people to notice when my car is sitting still and on the go. so you would suggest this cam for me? what is the difference in driveability? like will i hate it the more lopey it is? if so idc if it drives bad haha i want that LOPE!!!! haha
Old Nov 18, 2010 | 01:59 AM
01ssreda4's Avatar
Get a "thumper" cam from comp. That'll get you your lope.
Old Nov 18, 2010 | 10:19 AM
i need specific specs rite? idk much about cam work so i need a little more info haha
Old Nov 18, 2010 | 10:48 AM
TurboBuick6's Avatar
My 231 buick had a zero overlap (if i remember right, don't have the cam card any more) thing sounded like a BBC boat engine at idle lol.
Wait I remember now the LSA was 106.
Old Nov 18, 2010 | 11:46 AM
nice. but i still need to know either the full info on a cam that would be best or a site thast shows me the cam specs
Old Nov 18, 2010 | 12:11 PM
KevinR's Avatar
I really think the best sounding cam is the TRex V2 cam. 242/248 608/612 on a 110 lsa. But really, you can make a lot of cams sound "lopey" by tuning the idle down just a bit, if that's what you are really going for.
Old Nov 18, 2010 | 01:53 PM
BOBS99SS's Avatar
Captain Double Post
Just by the cam kit from texas speed,I think its 689,then a ls2 timing chain,ls6 ported oil pump,and some gaskets and a few bolts,I have a ms4 In my 99ss m6 and it sounds great,I love big cams ,just know no matter how good your tune is you will get a lil bucking at low rpms and some cam surge more or less depending on how good your tuner is,mine is tuned really well ,I went with the 4 because I all ready had an idea what I was gonna do with the rest of my build,12 bolt 4.30 gears,ls7 lifters,rod bolts,ported heads,ported fast ,and a lil spray,that all should get the most outta that cam,but u want your car to run good,what good is a good lope if it runs like ***, look into the ms3,or torquerv3 they both sound good,you could also get a custom grind,there are a lot of cams that have a good lope,but dont pick one based on a you tube video,and please care if your car runs like crap,I don't know if your stock or have bolt ons,but to get the most out of a cam swap get longtubes,ls6 intake,lid,ported tb,cat back or run, a cut out,good luck but make sure to call tsp and talk with them a lil bit before just buying something you will hate,
Old Nov 18, 2010 | 08:22 PM
masterz28's Avatar
Yeah if you want a cam for sound it can be had with a tune and just about around the Torquer V2 from TSP specs, check out ls1sounds and youtube .com for cams and what ever you like the car to sound, search more info on the given name go from there. I will PM a list of sites that sell popular cams.
Old Nov 18, 2010 | 08:30 PM
badss_02's Avatar
A (big) lopey cam is going to need some aggressive valve springs, titanium seats/retainers, and i would suggest chromoly pushrods. Unless your car has like 10k miles i would also do a new timing chain. You will need all of that, an oil pump o-ring, gaskets (water pump, timing cover, front main) and I would do an arp harmonic ballancer bolt rather than a stock one too... Stockers are not reusable btw. That being said I have a TSP MS4 for sale... It's big and lopey.
Old Nov 18, 2010 | 09:52 PM
99Bluz28's Avatar
Have TSP do a custom grind 230/230 111lsa w/XFI lobes
