Cal smog ?'s
Old Feb 25, 2003 | 10:56 AM
DreamWeaver's Avatar
Default Cal smog ?'s
About to order a cam here and am thinking on going with the TR224 114lsa but am concerned with smogability. Does this cam require alot of tuning to pass smog? Car is a M6 and I want to go as big as I can but still pass the sniffer test. Any California guys or gals have this cam grind and been to the sniffer???
Old Feb 25, 2003 | 11:59 AM
Cal's Avatar
Cal
Default Re: Cal smog ?'s
Hey I'm in the same boat as you, just a different state! My understanding is it will pass with some LS1edit tuning to eliminate idle missfire codes . . . anybody with experiance want to comment?
Old Feb 25, 2003 | 01:02 PM
strokedls1's Avatar
That cam should pass with the proper tuning, and elimination of trouble codes. No one will pass you with the SES light on. I had a 222 230 on a 114 that would pass the sniffer no problem. If you are worried you could always go with a 220TR on a 114 lsa grind.
Old Feb 25, 2003 | 04:58 PM
akw408's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Renegade:
<strong> About to order a cam here and am thinking on going with the TR224 114lsa but am concerned with smogability. Does this cam require alot of tuning to pass smog? Car is a M6 and I want to go as big as I can but still pass the sniffer test. Any California guys or gals have this cam grind and been to the sniffer??? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I passed with that exact cam, but had to bump up the idle to like 900rpms or so to do it. At stock 750 idle it wouldn't pass.
Old Feb 25, 2003 | 06:07 PM
SSBoy's Avatar
I passed the 15mph and 25mph test with that Cam here in So. Cal....
Old Feb 25, 2003 | 11:27 PM
sounds good then. Also as I understand it the 114lsa is a easier idle than the 112lsa improving idle passability. My stock idle is 800 and the plan is to have 2 edit files - 1 for max performance and 1 for smog - so I can just flash the smog file in before I go to get the cert (when time comes).
