AFR's, Darts, Trickflows, OH MY!
Do not buy dart heads. get trick flow or afr heads. I had afr 205 heads on a stock ci ls1 and with the boltons a non ported fast,stock waterpump,12 bolt rear w/4.11's i made 463hp@6,600 414tq @5,600 on a stang dyno and ran 11.1 n/a at 123-124mph. The car could of made 475hp with a ported fast and a e.w.p. I ran a lg motorsport g6x3 cam with it.
Buy a set of trickflow heads off of Total engine airflow
heres some of their work) LS6 motor,The Car even has a Air conditoner (full weight)
Heads,Cam,new valve train, headers
Hommey don't play Look>
9.98 @ 139mph
[youtube]FzLHN0TTbI8[/youtube]
9.98 @ 139mph
TSP head/cam pkg is the best price.243s by TEA are great.darts are good but need porting.AFR are great,but top dollar..look at vengeance racing trick flow head/valve train pkg.
What kind of power are you making with your TFS 220... Ya i have seen firsthand the power you can make wit TSP packages or just heads alone.. Just kinda wanna do something different around where im from, if that makes any sense...
Well generally speaking the higher the STR the less efficient up top. My STR is 2.5 which means it hits HARD off the line and costs me a little up top. I would guess I would see 510ish on a M6 and better exhaust (ditch cats w/bigger headers + duals or cutout) I would pickup another 20 or more....
#32
If money is an issue, like it is for so many, than TSP is probably your best bet. They are a one stop shop, and a great group of guys to work with. Just food for thought build your combo with room to grow, speed and power is addicting..good luck
#33
Yes I have been told about the "addicting" part.. It has become a bad habit but atleast my money goes to something I love doing... Thanks, I'll need all the luck I can get
#34
this has to be one of the most mis leading statements in this thread. Darts are a great head, but they do need porting to perform. Send a set of darts to any reputable head porter, and you will have a head that is plenty capable of doing more then what 90% of people on this forum need. That said, im not degrading AFR or TFS by any means. All are great heads in the right hands.
#35
I put some patriot gold springs on them before they were installed. The springs werent mandatory as the heads come with .600" capable springs and my cam is .598" but the xer cams are known for violent ramp rates so i opted for the little extra now to ensure the valves dont play tag with the pistons.
#36
When it comes to budget fast aint cheap and cheap aint fast. What you have to do is see what kind of money you have to work with and and buy accordingly. What I would do is buy used from a reputable seller.
The Darts are great once ported(more money after the buy).
AFRs and Trickflows are great out of the box(more money than Darts).
#37
LS1Tech Premium Sponsor
Checkout the PRC 215 heads, I think they will work great for your application. You can have smaller chamber options with better p/v & the PRC heads ship with the top of the line EHT spring standard!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
#38
Okay after alot of reading, i think i am going ot go with the TFS 220.. for the money there fairly decent in price and perform well and have good mid-airflow... Found out while reading that i will need to, let me rephrase that, recommended to run an after market roller rocker arm... I guess it has something to do with the stock rocker arm angle isnt slightly different then stock and will cause massive valve guide wear...
I read that the "early" tfs heads used 7.7'' long pushods and were prqcically incompatible with stock rockers..
The "late" geometry which used 7.5'' long pushrods which is basically stock gm geometry rolled 1.5 degrees...
now my question is... i will be running the tfs 220 heads... and more and likely buy some roller rockers as well.. how do i determine which pushrods i need and what roller rockers (i.e. 1.7, 1.8)
#39
https://ls1tech.com/forums/14109610-post32.html
You will need to measure the setup to determine the proper length pushrod.
