More LS1 RPM please?
Moving the powerband up is interesting, as long as it wasn't too spongy off of the bottom?
You may be able to get away with an LS6 cam.
We had a guy in our class make around 375hp with a LS6 crate motor, he had an LS1 intake and longtubes. This would be too much for our class, he de-tuned it, but I would like to avoid that. Are the heads different as well? Maybe that is where he was getting all that power?
Thanks again for all the ideas, I am really incouraged
Some guys mentioned light valves, who makes them and what are they made of? Are they durable over continued use?
I do not know whether these can be used with your stock (241) heads. When you check with TSP about your motor's crank/rod setup you could ask them about light weight valve options, if any, for your existing heads.
I have ferrea stainless 2.00 / 1.55 hollow, tuliped and undercut valves in mine, they are pretty damn light, dont remeber the #'s though..
