More LS1 RPM please?
I am building my LS1 for road racing, it is completely stock at this point with the exception of some 26918-16 Comp Cam Valve springs. It dynoed at 311hp and 330tq with a full exhaust and no headers. I have long tubes, a 2into1 dr gas boom tube, ARP rod bolts and an Improved Racing Baffle set up for the oil pan all ready to go in.
My question is, I am looking for stone cold reliability and around 1000rpm more out of the car (i need it for stretching gears out from corner to corner).
What besides moving the rev-limiter with the tune will I need to do this? I am willing to change whatever to get there, I am sure that with what I have I will be close to my desired 345hp and 355tq, So I am afraid of a cam (these things make so much power stock, poor little mustangs) but do I need one for the RPM I desire or are the valve springs enough?
What about rotating assembly? It seems that most people think it will be fine, any thought?
Thanks for the help
Thanks for the help
It is stock, I can use any cam I want I am just limited by hp/tq to wieght. I like the characteristics of the stock cam, good power under the curve, I just need to move that rev-limit up. And not worry about the engine staying in one piece.
Sorry, I am currently running 26918-16 Comp Cam Valve Springs.
I am not sure on RPM maybe 6500-7k would be perfect. What is the stock revlimiter set at 5500? I am looking for another 1000 +/- over stock.
Does the cam affect valve float?
My fault, you reported your valve springs in the first post.
I think you could get the valve train to sustain 7k rpm levels with the following:
Morel lifters,
Comp Cam Hardened Push Rods or the eqivalent,
Comp Cam 921 valve springs (or PAC 1221s, or the TFS equivalent),
Upgraded OEM rockers using either the Comp Cam or Harland Sharp trunion upgrade).
As for a cam, the stock might work but I would be tempted to have PatrickG spec one on EPS lobes, which make for a stable valve train.
I will defer to others concerning the bottom end of the motor. I suspect that sustaining 7k rpm will require at least setting up the rods and crank for that. The ARP bolt upgrade, which does not work for everyone, is more for "visiting" 7k rpm, such as in drag racing as opposed to living there as in road racing.
Morel lifters,
I will defer to others concerning the bottom end of the motor. I suspect that sustaining 7k rpm will require at least setting up the rods and crank for the that. The ARP bolt upgrade, which does not work for everyone, is more for "visiting" 7k rpm, such as in drag racing as opposed to living there as in road racing.
Morel lifters,
Yeah I am thinking the same thing about the bottom end.
Cam, lifters roller rockers pushrods 1518's (depending what type of cam may need 1521's). That will get you a pretty solid valve train.
ive never road raced or anything but if i had any valve springs to suggest, ive been using patriot gold extreme springs , cryo-treated and have had great luck , we will see how much spring pressure i have lost in a few thousand miles but i bet not much, and with a double spring valve floating is less likely
Could a cam be done that would give me those extra rpm with out a ton more peak horsepower? Maybe 7k is too far what is the stock rev limit?
Morel lifters,
Morel lifters,
I will take your advice and get with TSP for the rockers, valve springs and pushrods maybe they can get me some numbers for a bulletproof bottom end.
Thanks for the input.
How much power can you make?
You can get cam that will make much better torque up high than the stock cam and help you cut down on your shifts. Even if you keep your stock cam if you plan to spin it like you want to you need springs and hardened pushrods minimum or we will eventually see you posting another another "LS1 carnage threads"
Get Geoff at EPS or Patrick G to spec you a custom cam to suit your needs.....
Yeah kinda want to stay out of there! Lol I can make around 345-350 depends on how heavy I keep the car? I will get with both of those guys and sound like pushrods and better springs for sure. I need to read up on those trunion bearings. Any threads for that?
Don't know if I would trust the bottom end to repeated 7k runs. All the valve-train upgrades listed here are good suggestions, however, I don't think duals are needed for a stock cam. The 918s are already a big improvement over the stock weak springs.
I would say an overall upgrade will be needed for prolonged runs up really high. I understand that the HP up high is not what u are concerned with, just spinning her. I would recommend a bottom end build as well tho just to fret on the safe side...
If u just want to spin the hell out of the thing that just getting a good top end component setup would be the ticket. Hardened push rods, rockers, GOOD springs, litters, etc... The stock cam along with all of the components will turn the RPM u need, but won't make power much after 5900 or so. That will get you your desired RPM range, but u will be running on a ticking time bomb...
How long will your bottom end hold while pushing 7k for prolonged periods of time??? 1k miles... 20kkk? Who knows, but it's going to end bad even if your tune is damn good.
Have u considered gearing changes??? Instead of needing more RPM to sustain power through a corner, how about changing the gearing to accommodate, and allow you to keep your engine in the 6000-6200RPM range(or lower). That way you will be stressing the bottom less, and you will be keeping your car closer to is peak with the stock cam and a good top end setup.
Just a thought... But either way I'd say at least get a good rotating assembly.
