Lube crank and cam cover seals or not?
Re: Lube crank and cam cover seals or not?
No lube on the cover seal (I'm assuming you are talking timing cover here), it has a hi-temp silicone bead already on it. The crank seal (aka pulley seal), is not lubed either, however you lube the outside of the pulley hub when you install it.
<small>[ February 25, 2003, 11:26 AM: Message edited by: Dave Carney ]</small>
