Need cam with more BOTTOM END Torque, look at my current cam setup
For the sake of comparison, my car made 390 rwhp and 388 rwtq (6-speed) with only a mild cam and bolt ons. Trick Flow 228/230 .585/.585 112 LSA.
Added similar heads and ported FAST and put down 440/408. I'm sure you're losing a bit on the dyno with the A4, however I think with a milder 228 - 232 cam you would see much better power under the curve.
Your not crazy at all, that donkey dick cam has no place in a stock displacement engine. Retire that behemoth in for something along the lines of a 228/232 or 230/234. Better under the curve power and you'll probably end up making more HP and Torque than your current setup. Take some time to search and you'll find tons of setups similar to yours that make as much or more power with a smaller cam.
