Switched from G5X2 112 to G5X3 114... first thoughts!
Originally Posted by Dope
Just drop your idle down to 500rpm for that killer idle again
Dope
Dope
Originally Posted by WS6snake-eater
You do not have to flycut with the G5X3 on 112, with stock deck height heads. I have it in my car, and it is within tolerance. I've got PP Stage II LS6 heads, which are stock deck height, and am using the GM gaskets. It will fit fine. FWIW, I would still check valve drop before taking my word for it, because it is close and every setup is different. I'm just speaking from my experience, I did not flycut.
pray you don't float a valve
Originally Posted by johnboy
I am really debating between these two cams.... main reason to go with the X2 over the X3 is cause of the killer idle. Idling it down will actually give this same idle?? Seems like the car wouldnt idle as good as the X2 with the idle being this low?? I am not the sharpest tool in the shed though!
Can't quite remember off the top of my head what the valve drop was, but I do have it written down somewhere, and I'll see if I can find it. Lou walked me through it on the phone and I was within tolerance. I'll see if I can find my old figures.
