Do rectangular port heads fit LS1 blocks?
Old Nov 28, 2010 | 06:23 PM
bayer-z28's Avatar
Default Do rectangular port heads fit LS1 blocks?
The rectangular port heads.. Those are for a 4.00"+ bore, right?? Wondering if I can do a set of rectangular port heads on my LS1 block.. I'm a little behind on this subject. From what I remember, those were LS3 and LS7 heads.
Old Nov 28, 2010 | 07:47 PM
jdiddyws6's Avatar
Unless you buy MM small bore heads.
Old Nov 28, 2010 | 07:57 PM
SOMbitch's Avatar
^^^^what he means is OEM L92/LS3 heads no but Mast Motorsports makes a nice small bore rectangular port head...$$$$$$
Old Nov 28, 2010 | 08:02 PM
Arc00TA's Avatar
Square port only work on 4.000+, LS2, LS3, L92 etc. Pretty much gen IV motors. They will also work on LQ4/9.
I think some other companies have started looking at small bore sqaure port heads as well, but none of them will be cheap.
Old Nov 28, 2010 | 11:42 PM
01ssreda4's Avatar
Truth of the matter is the LS1 has become the next dinosaur. Its becoming the LT1. It's dated. It's ancient. Move on folks
Old Nov 29, 2010 | 11:01 AM
bayer-z28's Avatar
^ Yeah, exactly.. I'm finding that they are mostly on 4.0" and up bore blocks and engines. 4.06" LS3, 4.00" LS2 and 4.125" LS7. I'm just confused about the casting #'s other than 241 and 243's.
K.. Than answers it.. Thanx.. Was just curious.. I don't feel like dishing out obscene amounts of money for the heads to fit mine. I'd rather just go out and get an L99 block.
Old Mar 10, 2022 | 02:31 PM
tdmaker's Avatar
Default thanks 12 years later!
thanks for the valuable info!
