Wear mark under cam bearing
So I am in the process of building this eBay engine for a Volvo wagon and yesterday noticed a strange wear mark while getting ready for the cam swap. Could be a machined place but if so it's suspicious cause there is a small rolled lip at the end and it is super close to the bottom of the cam bearing. This is my first LS to play with so thought I'd see what the gurus here have to say. The crank looks fine with no marks that I can find. I haven't checked the crank end play as of yet as I ran out of time working on it yesterday. What do you all think?
Seconding installing new cam bearings, they're cheap.
The following users liked this post:
chattownls (03-08-2022)
Ls7colorado (03-09-2022)
chattownls (03-09-2022)
G Atsma (03-08-2022)
So I know everyone is talking about the cam bearings but I was actually talking about the half moon spot under the cam bearing. I made some arrows..
This?
Hello,
If you are asking about this in red, it is just normal a factory clearance cut.
The rolled lip could just be a burr left by the mill cutter.
Hope this helps.
Hope this helps.
chattownls (03-10-2022)
I am new to this forum so I guess everything has to be approved or whatever but I tried to post a pic with arrows yesterday morning.
Yes, the area you circled in red is what I was referring to and you answered my question perfectly. I really appreciate it and I thank everyone for the recommendation of new cam bearings. I will be doing that shortly. Thank you all!
The following 2 users liked this post by chattownls:
bbond105 (03-10-2022), Metalchipper (03-10-2022)
