Early and late model 24 tooth reluctor wheels interchangeable?
Old 11-29-2010, 10:42 PM
dgman10's Avatar
Default Early and late model 24 tooth reluctor wheels interchangeable?
hi
i have to repalce the reluctor beacse of damaged teeth i have the early 24x reluctor and it doesnt have any gaps between the teeth, the newer 24x reluctors have differant spacing and small gaps. i am wondering if you cange change to the new style without changing anything else.
thanks any info will help
Attached Thumbnails Early and late model 24 tooth reluctor wheels interchangeable?-reluctor-20gap-20diff-20project-202010.jpg
Old 11-30-2010, 09:33 AM
O2Form's Avatar
I wouldn't see why it should matter, it doesn't read the gap it reads the spaces between the notches.
Old 11-30-2010, 10:03 AM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
As long as it is a 24x reluctor wheel going back in you will be good to go.
Old 12-01-2010, 10:34 PM
dgman10's Avatar
Talking
thats great, thanks guys. i also found out that the spacing makes it easier for the sensor to read so that it doesnt throw a code, and it is a good idea to upgrade to the newer version if possible
Quick Reply: Early and late model 24 tooth reluctor wheels interchangeable?
