FI engine question... strength of stock crank
Now let's take this hypothetical motor and swap in some good rods and pistons, and add head studs along with some good head gaskets. Again, assume a perfect tune. What would be the most likely failure?? Crank?? Cylinder liner??
Does anyone know the HP limit of the stock crank??
Thanks for any input.
Of course, I could be wrong. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
If i were to wager, i'd say it's a toss up between the rods themselves or the pistons. My biggest concern is the pressed wrist pin first. Bend one a little bit, and you'll take out the bore/piston once it binds.
I'll run the stock crank till i spit it out and drive over it <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<strong>
Thanks for any input. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I get this question alot at ARE...
We have tested to over 700RWHP with a stock crank, but with good rods and Ross Pistons. It was a F-car with a single turbo and it went high 9's!
Realistically though, 600rwhp should be pretty safe.
