Could this setup run 10.00??
Old Dec 7, 2010 | 12:27 PM
Fastdriver1992's Avatar
Default Could this setup run 10.00??
my motor might be broken going to check it this week. i would like to run a 10.50 index next year which means i want this car to run 10.50 on a hot summer day. i was thinking of
Putting a Stroker Crank and rotating assemby in my LS6. and get a bigger camshaft. the top end is all built up right now with prw rockers, dual springs, hardened pushrods, comp r lifters. the car rn has what is listed below on my signature. the car weighs 3050lbs wit me in it and a 4000 stall. could i put a big enough cam in this motor to run this fast?
Thanks
Anthony
Old Dec 7, 2010 | 12:30 PM
NitrousExpress's Avatar
Ls1tech & Truck Sponsor
Can a stroked ls6 run a 10.0 at 3050 raceweight? Yes.
Old Dec 7, 2010 | 02:06 PM
mike c.'s Avatar
my stock cubic in ls1 ran 11.1 @123-124mph at 3,680lbs with me in it. I think you can...
Old Dec 7, 2010 | 05:11 PM
garygnu's Avatar
chrss1313 runs 10.00 with a 346 and TFS heads.get a EPS cam .
Old Dec 7, 2010 | 05:51 PM
Minshall's Avatar
I run 10.3Xs cam only. Im right there with you on race weight. So i dont see any reason why you couldnt.
Old Dec 7, 2010 | 06:14 PM
ok cool thanks guys, im either doing that or im putting in a supercharged SBC thats in my dad's car. but i really want to run this LS motor
Old Dec 7, 2010 | 11:08 PM
blocc monster's Avatar
wat setup are u runnin?
Old Dec 8, 2010 | 12:19 AM
180ls1's Avatar
Well i would get a different cam more agressive lobes and more duration, depending on your stall. I would also have your heads ported/milled and see where that gets you. A FAST intake will also help you but you might not need that to get to 10.50's
Old Dec 8, 2010 | 09:06 AM
well the car is carburated not EFI. i'm not touching the heads i just want a new rotating assembly and a bigger cam
