What pushrods do I run with LS7 lifters
Old Dec 7, 2010 | 06:25 PM
98mystic_maro's Avatar
Question What pushrods do I run with LS7 lifters
ls7 lifter #17122490
I need to know what pushrods to run with these lifters. I need to make sure because I'm finishing my build and need to make sure this thing goes right. Help Please?
Old Dec 7, 2010 | 07:25 PM
Darkman's Avatar
If you are asking about pushrod length, the standard procedure is to take measurements using an adjustable (measurement) pushrod. What components are you changing?
Old Dec 7, 2010 | 08:36 PM
BStowers023's Avatar
LS7 lifters are a factory replacement, you should be able to run the same length as you would if you kept the stock ls1 lifters.
Old Dec 7, 2010 | 08:38 PM
supersick99z's Avatar
I went from a 7.4 to a 7.350 after I installed LS7 lifters, but they are all different depending on cam.
Old Dec 8, 2010 | 12:07 AM
01ssreda4's Avatar
Measure. No ifs, ands, or butts about it dood.
Old Dec 8, 2010 | 09:41 AM
I have an ms4 cam I changed to the 675. lift springs from texas speed and i'm running stock rockers. I didn't mill the heads or deck surface so that is the stock deck height.
Old Dec 8, 2010 | 09:54 AM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
Typically we will have to go with a little shorter pushrod with those lifters but like mentioned earlier I would definately measure it out to be sure. You can get the comp pushrod length checkers for $20, saves a lot of guessing and headaches in my opinion.
Old Dec 8, 2010 | 10:47 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Factory replacement, yes...but they do have a bit higher cup height than the older LS1/2 lifters, so they require a different length pushrod.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Dec 9, 2010 | 07:04 PM
2fresh's Avatar
any info on the length with those and a ls6 cam?
