228r what lsa to go with?
Where it makes power peak is going to depend on ICL (as well as intake, heads, and exhaust to some extent)... so it sort of depends. I think they are ground with the default Comp 4* of advance.
I would be tempted to try a 224/228 110LSA(+0) if you want XER lobes.
In general, the 110 will have have slightly higher peak power but will fall off faster after peak. I don't think it will be night and day since you are talking a couple degrees. If you start throwing advance or retard in there you might see more of a difference... I don't know what the "default" amount of advance there is on the 228R, and if you chose a 110LSA it would be a custom cam so you could spec the ICL of your choosing (or someone at TSP could help you out with that).
Say you are comparing a 228R with 110LSA+0 to a 112+2 (2 degrees advance so 110ICL as well)... real guru's stop me if I post complete nonsense below:
Quick and Dirty Cam Calculator Spreadsheet
________________________________________0.006 __ 0.050 __ 0.200
Intake Duration - ID_______________________ 277 __ 228 __ 149 XER 3724
Exhaust Duration - ED______________________277 __ 228 __ 149 XER 3724
Lobe Center Angle - LCA (also known as LSA) 110 __ 110 __ 110
Intake Centerline - ICL____________________ 110 __ 110 __ 110
Intake Valve opens - IVO___________________28.5 __ 4 __ -35.5 BTDC (- indicates ATDC)
Intake Valve closes - IVC__________________ 68.5 __ 44 __ 4.5 ABDC
Exhaust Valve Opens - EVO_________________ 68.5 __ 44 __ 4.5 BBDC
Exhaust Valve Closes - EVC_________________ 28.5 __ 4 __ -35.5 ATDC (- indicates BTDC)
Exhaust Centerline - ECL___________________ 110 __ 110 __ 110
Overlap__________________________________57 __ 8 __ -71 degrees
Intake Duration - ID_______________________ 277 __ 228 __ 149 XER-3724
Exhaust Duration - ED______________________277 __ 228 __ 149 XER-3724
Lobe Center Angle - LCA (also known as LSA) 112 __ 112 __ 112
Exhaust Valve Opens - EVO_________________ 72.5 __ 48 __ 8.5 BBDC
Exhaust Valve Closes - EVC_________________ 24.5 __ 0 __ -39.5 ATDC (- indicates BTDC)
Exhaust Centerline - ECL___________________ 114 __ 114 __ 114
Overlap__________________________________53 __ 4 __ -75 degrees
_________________________________________0.006 __ 0.050 __ 0.200
IVO delta__________________________________ 0 __ 0 __ 0
IVC delta__________________________________ 0 __ 0 __ 0
EVO delta__________________________________ -4 __ -4 __ -4
EVC delta__________________________________ 4 __ 4 __ 4
ECL delta__________________________________ -4 __ -4 __ -4
Overlap____________________________________ 4 __ 4 __ 4
I apologize if the formatting didn't come out. As you can see since the intake valve opens and closes at the same time for these two cams they will have a somewhat similar location for peak power and torque. They will make identical dynamic compression. However the total overlap is different and the location of the exhaust valve events is different.
For the 110+0, the exhaust valve opens at 44* (0.050) BBDC compared to 48* for the 112+2. That means the 110+0 should make slightly more torque because of the slightly longer power stroke. The difference in the 8 degrees of overlap for the 110+0 versus the 4 degrees for the 112+2 means that the 110 will idle rougher, have a little less idle vacuum... the 110 should also carry power a little better past peak since it has a little more overlap and the overlap is centered right at TDC, whereas the the 112+2 is centered slightly before TDC.
All in all there won't be a tremendous difference but there will be a difference nonetheless. If you start throwing the 110 and the 112 on vastly different ICL's than the comparison would depend on which ICL you pick for each one.
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
How come nobody answers the phone when I call your shop? I'd like to pick someones brain about cam selection before I start throwing $$$$ your way. 2. Yes.
3. 200-300RPM past power peak... so that will depend on where the peak actually is on your motor. If you do a 228/228 on a 112 LSA with 4 degrees of advance it, the IVC is 42* ABDC... so I think like a 6100-6200RPM peak. With 2 degrees of advance it would be something like a 6300-6400RPM peak.
2. Yes.
112 is what i would get.
