need help ASAP
Old Dec 16, 2010 | 10:08 PM
super mario's Avatar
Default need help ASAP
i tightened my rod bolts and main cap bolts to 18 ft pounds...is that enough or no? i need help so my engine can become complete and im scared of throwing something
Old Dec 16, 2010 | 10:27 PM
Randy WS6's Avatar
Hope this helps
http://ls1howto.com/index.php?category=1
Old Dec 16, 2010 | 11:20 PM
01ssreda4's Avatar
My advice, take the engine to someone who knows how to assemble it.
Old Dec 17, 2010 | 08:49 AM
KCS's Avatar
KCS
Moderator
Stock bolts? 18ft-lbs is ok if you plan on tightening further to the angle GM specifies, but if it's not obvious to you that they will need more than 18ft-lbs then you probably aren't ready to build an engine by yourself.
Old Dec 17, 2010 | 09:36 AM
jcob's Avatar
then the 80 degrees on the inside bolts and 50-55 degrees on the outside bolts
