Cost to sleeve a LQx block
DM
I would imagine MID sleeves would cost are pretty much the same as doing an aluminum block since it's basically the same process, but I think if you're just sleeving it down for a smaller bore, you can do that for pretty cheap since the sleeves are cheap (RE: Badger sleeves) and I don't think the process is as complicated as an aluminum block.
If you want 4.250" bores, the iron GMPP LSX block will do that too.
World's Warhawk block is another option
It is however expensive to do because iron machines much more slowly than aluminum. It would run right around three grand to MID sleeve the iron GM block.
I do machine the 6.1 Hemi blocks for MID sleeves, with three on the way in right now in fact.
The LSX iron block is a cheaper alternative but of course the cylinder walls are on the short side for long strokes. It may be possible to dry sleeve the LSx blocks using the 5.8" long Darton Seal Tight dry liners. I will check that out next time I get an LSx block in.
Steve
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
You also bring up one reason I have been looking into this... My crank is a 4.125 so to have a deeper cylinder is one reason I've been looking into this. And to have a 4.2 bore with a 4.124 would make for a dirty little ***** of a motor
DM
Let me attach a photo of the one I did for Erik, prior to decking and finish boring, so you can see what it looks like.
Steve
DM
Steve Demirjian
Oceanside, Ca.
760-630-0450
Steve
So it's about $3k to do this to a LQx... I still have my LS1 in the Bird, what would it run to sleeve that with MID or Dry with a long sleeve for a 4.2 bore?
DM
