How do you set rocker arms.
Old Feb 25, 2003 | 05:00 PM
JESSIE's Avatar
Default How do you set rocker arms.
I'm installing a new cam 224/224 581/581 112 I've already installed the cam and the springs. I've also already put the pushrods in and pushed the lifters down to where they are touching the cam. Now I'm at the stage where I need to set the rockers. I read the directions that came with the comp cam but they do naot specifically say how to set them on an LS1. I've done this many times on early model carburated engines, but i always pulled the intake and always had adjustable rockers. So any info is greatly appreciated for I am nearly finished with the cam install and anxious to drive it. Thanks Jessie.
Old Feb 25, 2003 | 05:26 PM
JESSIE's Avatar
Default Re: How do you set rocker arms.
ttttttttttt
