Cast iron 5.3 blocks
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
But I have to ask this cause I am about to start on this project engine.
Does any cylinder grinding/clearance work have to be done to the 5.3 LM7 block GEN III (12567392 block ID number) in order to make the 383 stroker?
Can you use a stock 6.0 crank for it's 4 inch stroke and use forged rods and pistons to obtain this 383 CI displacement?
If the answers to the above are no for clearance work and yes on the crank, what kind of power levels would the engine hold up to reliably? And I do plan on using nitrous for drag racing (primary use of the engine).
And has anyone actually gone out to a 4.00 bore and the engine survive race use? I don't expect it to last for forever.. just a good season or two would suit me just fine. That will give me time to get another engine together and ready to go in when this one bucks the kicket.
if you want a 408 just start with a 6.0l block and be done.
